nozzels or whole injectors - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-08-2013, 08:02 AM Thread Starter
Drift101's Avatar
I am looking to get a little more power out of my truck right now i'm on the stock turbo with a basic ts chip, 4" exhaust and intake, i saw that i can get 100% over stock nozzels for the stock injectors is it worth doing just nozzels for now because its half the price of stage one injectors or should i just wait save the money and get injectors, i plan on rebuilding the stock turbo maybe with a 1.0 exhaust housing and a new ww2 its a bit cheeper than buying a
38r at this point also thinking of getting a modded hpop just to freshing things up, already have upgraded fuel spring at the bowl, let me know your thoughts on this just trying to figure out which route to go
thanks
02 F250 CC
K&N intake,ts chip, 4" lift on 35's, 4" exhaust
Drift101 is offline
post #2 of 3 Old 06-08-2013, 08:09 AM
Quoted: 3 Post(s)
Id just go with custom tunes for now over nozzels. Maybe the ww2 as well if your gonna hang on to the stock turbo for a while.
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #3 of 3 Old 06-11-2013, 08:52 AM
Premium Starfish Member
AzPatMan's Avatar
Quoted: 31 Post(s)
I wouldn't put in nozzles by themselves. If you're going to tear into an injector to upgrade it - you may as well rebuild it.
For the extra couple hundred - may as well get the upgraded/rebuild injectors that have a warranty on them from someone.
But if you're comfortable working on the injectors - then get what you need to do the work yourself. Pretty much what I did for my turbo rebuild/upgrade. Granted turbos are easier to work on then injectors , but you get the idea.
2003 EX, 7.3L 4inch Lift, Nitto Trail Grappler's, KMC XD Spy's
220k Miles, Currently 605tq, 312hp
AzPatMan is offline
