6 POS tuner vs Custom Tune - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-07-2013, 07:21 AM Thread Starter
bfitch's Avatar
so right now my truck has a custom tune on it. the previous owner took it to a local shop, who then put it on a dyno and tuned it. well im currently working with my buddy on upgrades and im looking to get around 450hp. he gave me a list the other day and on the list was a TS 6 POS tuner. he said he liked it because you can dial the power, and i agree that is nice, but if im not mistaken, the truck has to be off for that, right? also, this truck isnt a daily driver, i have a ranger and a motorcylce for that. but it will be pulling my bass boat on trip that could be up to 3 hours long, and i will drive it around every now and then because, well i like to drive it . so do you think itd be better to go with the 6 POS or just take the truck back to the shop and have it dyno'd again?
E99 F250 SD 7.3 ECLB 5in exhaust, intake, built trans, WW2, T500 HPOP, mechanical wastegate and a custom tune. more to come
bfitch is offline
post #2 of 4 Old 06-07-2013, 07:26 AM
Macon's Avatar
Just putting it on a dyno does nothing but give you numbers. If the shop is tuning while on the dyno, then they should have what's needed for a TS style chip as well. The chips are switch on the fly. Let off the throttle, rotate to desired slot, continue. And tuning while on the dyno will provide much finer tunes. But, if they're just putting it on the dyno to see how she does, then nothing is being accomplished.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #3 of 4 Old 06-07-2013, 07:42 AM Thread Starter
bfitch's Avatar
yea the guy was tuning it on the dyno. i didnt know they were switch on the fly, thats how my cummins was and i liked that. now can i get a 6 POS and have one of those set up as a custom tune?
bfitch is offline
post #4 of 4 Old 06-07-2013, 08:55 AM
Quoted: 6 Post(s)
Basically all of the tuners (Gearhead,PHP, DP, Tony Wildman,etc) have "custom tunes" for these trucks. They usually are around $450-$500 to have them on a 6 position (TS Chip burned with their tunes). PHP has the Pheonix Chip that is fairly cheap in comparison - $295 with their custom tunes on it or you can get the Hydra Chip that has up to 17 tunes (all of their tunes are available to you) that accepts other peoples tunes as well, all can be uploaded from email through the USB.
From what I've found, these are all tunes that are pre-written to specific year trucks (HEX Codes on the computer). If you upgrade your turbo, injectors, etc then you'll have to have another tune written specifically for your truck. Those are definitely a true custom tune specifically for your truck. That was my reasoning for going with the Hydra. PHP Charges $25 for their custom tunes and it will be emailed to me/uploaded within minutes.
With a 6 position chip, you'll have to remove it, mail it in, have it burned, and mailed back/re-installed. DP has a similar option as the Hydra as well but I think its more money.
Comparing a customer 6 position/hydra chip to a canned TS Chip or similar tuner (I had a Diablo Predator) is night and day. My 80DD tune is much faster than the 100 Extreme tune on the Predator and shifting is so much better.
2006 F250 CC/SB 6.0 Diesel
SCT 3015, Straight Piped
2002 F350 CC/SB 7.3 Diesel- SOLD
-PHP Hydra, 6637, Diamond Eye DEP-510215 Muffler Delete, GlowShift Triple Gauge Cluster.
-Plans: JW Valve Body & 6.0 Torque Converter/Cooler
bikeluver43 is offline
