Injectors and turbo mods - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-05-2013, 08:04 PM Thread Starter
OK guys I know there are a few threads on here but Im looking to get some up to date information. In the near future (aka once I get enough money ) I am looking to get some higher performance injectors, im thinking the stage 2's. Since this is my daily driver I want to also do all of the supporting mods, such as turbo and HPOP and......? any thing else? What are some good brands for aftermarket injectors? And how about turbos/ turbo kits? Basically looking for a list of products that I need and companies to go through when ordering.
2000 F250 Extended Cab/Short Bed 6 speed manual
4" Pro Comp Lift
Gauges
4" Exhaust to a 7" tip
AFE stage 2 intake
PHP Hydra Chip
35x12.5x16 Toyos
Micky Tompson Rims
robertTennigkeit is offline
post #2 of 4 Old 06-05-2013, 10:59 PM
CSIPSD's Avatar
Your in cali...
Your pretty much screwed.
Otherwise for a fun DD truck...
160/100's
38R turbo
and supporting mods.
no hpop required, no fuel system required, just a fun 375-400hp truck to drive.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 4 Old 06-06-2013, 12:40 PM
blue99stroker's Avatar
Quoted: 289 Post(s)
ya im in the same boat. luckily the 38r looks like the stock turbo and its made by garret. lol
im going to go the same route as well.
rosewood and full force make good injectors.
a cheap upgraded hpop is the t-500. its about 450.
and instead of doing a regulated return which is 600 bucks, you can get riffraffs Frx for under 200.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger/sonnax shift kits, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #4 of 4 Old 06-06-2013, 02:03 PM
Macon's Avatar
Ah, a Cali truck. I can't tell you what you should do since you not only smog, but you smog differently depending on where you live. With that, said... Stage 1 single shot injectors to start off with. You're going to need tunes to support that, or whatever else you do that isn't a filter and pipe. T500 HPOP is on my list, but it's not a "must have" with Stage 1. You can go 38r (with a WWgen2), WWgen2, or wait for new and improved whatnot. I can't, and wouldn't, tell you which brand you must get. I will say to buy from a reputable maker/tuner. It sucks for the good startup guys, but everyone began as a startup. Unless you have a buddy you're willing to test for, don't be a tester. Use tried and true.
What is your end goal? If it's big numbers, the answer will be much different than above. If it's DD, reliability, and better than as it came from Ford, then we're good.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
