6637 DIY intake question - Ford Powerstroke Diesel Forum
post #1 of 17 Old 06-02-2013, 12:37 PM Thread Starter
So I just installed the 6637 intake but it was a little too big, and when I closed the hood it kind of dented the filter, is this okay? I don't really notice a sound difference, but when I'm driving I seem to accelerate a little faster, and the RPMs take longer to shift. Also when I turned off my engine, there was a hissing noise coming from around the area of the first pic. And it eventually dies off, is this normal? Thanks!
j90reaper is offline
post #2 of 17 Old 06-02-2013, 12:42 PM
blue99stroker's Avatar
Quoted: 247 Post(s)
Ya the hood squishes the filter a bit. I got the exact same setup as you did for my dad.
The whoosh sound when you shut the truck off is just air going back out the filter. The stock intake does this but you don't hear it because it's enclosed in a box
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #3 of 17 Old 06-02-2013, 12:58 PM Thread Starter
Ohh okay, I actually had the K&N filter before, but for some reason when I was installing the filter, the 4" pipe wouldn't go too deep into the rubber tube so is this going to be a problem? Will there be any leaks, 2nd pic of filter, I clamped them up good.
post #4 of 17 Old 06-02-2013, 02:26 PM
Quoted: 247 Post(s)
Should be fine I noticed the same thing when I installed it on my dads truck. I thought about cutting the adapter piece and making it shorter
post #5 of 17 Old 06-06-2013, 10:17 PM
Quoted: 14 Post(s)
I didn't have any issues with the filter touching the hood when I did my DIY 6637 setup. I cut out a bunch of the stock airbox, that may be the difference.
ttyR2 is offline
post #6 of 17 Old 06-07-2013, 08:09 AM
Quoted: 6 Post(s)
Mine had the same thing happen, don't think it makes a difference. Mine also makes a "whooshing" sound sometimes between gears and if I stab the throttle and let off, almost sounds like a blow off valve- but I like it.
2006 F250 CC/SB 6.0 Diesel
SCT 3015, Straight Piped
2002 F350 CC/SB 7.3 Diesel- SOLD
-PHP Hydra, 6637, Diamond Eye DEP-510215 Muffler Delete, GlowShift Triple Gauge Cluster.
-Plans: JW Valve Body & 6.0 Torque Converter/Cooler
bikeluver43 is offline
post #7 of 17 Old 06-07-2013, 08:12 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
have close up pics of your set up's?
2000-7.3L is offline
post #8 of 17 Old 06-07-2013, 08:24 AM
Quoted: 6 Post(s)
I can snap one this weekend, my truck is at home. I went a different route and bought a 4" adapter for a sheet metal dryer duct (Item# 39734 @ Lowes, $3.97). Fits nice and snug in both the air filter and the intake tube, doesn't restrict any air (that the 3.5" PVC does). Total into my setup is abour $35
6637 @ everythingtruckparts.com = Donaldson B085011 Air Filter
B0850111 $26.75
post #9 of 17 Old 06-07-2013, 08:29 AM
dannanw's Avatar
Quoted: 54 Post(s)
Garage
here's mine on E99...
dont hit at all
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #10 of 17 Old 06-07-2013, 11:00 AM
Quoted: 14 Post(s)
Mine:
I built a PCV system and cut off the little oil breather "scoop" in the plastic support tube in the stock intake system and plugged the resulting hole. Then added a short piece of exhaust tubing into the air filter.
ttyR2 is offline
