38r duability - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-02-2013, 04:32 AM Thread Starter
rosshurlow1's Avatar
38r duability
After considering getting a new turbo and talking to a hard headed diesel mechanic he said he hates ball bearing turbos because he got one for his powerstroke and locked up after 3000 miles, have there been cases like this with the 38r,and how many miles do you have on your 38r or expect it to last for
rosshurlow1 is offline
post #2 of 11 Old 06-02-2013, 04:40 AM
Quoted: 822 Post(s)
I love mine. I expect to get well over 100k miles. Just got to keep up the oil change maintenance. His line of reasoning is retarded. He would probably blame the dog for taking a dump in the wrong spot in the yard for causing the stock market crash. Lol
Corey@CNCFAB is offline
post #3 of 11 Old 06-02-2013, 06:30 AM Thread Starter
When you got it did it have a good bit more power? Did it make it more driveable with the quick spool up? Did you see any mpg gain?
post #4 of 11 Old 06-02-2013, 09:56 AM
Quoted: 822 Post(s)
Yes. Yes. Yes. Cleaned up my exhaust too, meaning my truck doesn't plum a bunch coal dust when I get on it.
post #5 of 11 Old 06-02-2013, 11:39 AM
blue99stroker's Avatar
Quoted: 272 Post(s)
I bet the mechanic who blew his 38r installed the pedestal too tight. The orings squish out and limit oil flow through the pedestal. Then the turbo does not get enough oil.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #6 of 11 Old 06-02-2013, 01:35 PM
Justin@DP-Tuner's Avatar
Quoted: 61 Post(s)
The 38r is a great drop in turbo and will last a long time, even at higher boost. I think I would disregard the mechanic in question's advice. His logic is very flawed.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #7 of 11 Old 06-02-2013, 02:16 PM
hey hucorey noticed in your sig you got the WW2 in on your 38R, how do you like it?
and to the OP, I've been beating the dog sh%$ outta my 38r for over 3 years now. Had it to its limit and over its limit many many times.. havent once had an issue with it...
2000 F350, 10"s 38's, 4.56 gears/lockers, Dynatrac high steer w/free spin hub kit, 5" strait piped, DIY intake, 38R,Swamps 250cc, H-11 Studs, 910 Springs, Smith Brothers Pushrods, Adrenaline,Sinister Diesel Fuel System, CCV Mod, non ebv Ped. with high-flow outlet, Bellowd up-pipes, Built tranny, Gearhead Tunes.
strokin'patty is offline
post #8 of 11 Old 06-02-2013, 06:21 PM
Quoted: 822 Post(s)
I like it, but honestly, I really don't have anything to compare it to. When I got the 38R I ordered the WW2 at the same time. So the turbo got installed right away with the new wheel. All I can say is that it most definitely spools up quick.
post #9 of 11 Old 06-02-2013, 09:53 PM
dentexpowerstroke's Avatar
Not to derail but I wanted to point something out. The guy that asked about how the ww2 does, adding a different compressor wheel won't allow the 38r to handle bigger injectors, the 38r downfall is the turbine side of it. It also has a smaller exducer on the compressor side than most turbos around its inducer size. With 250s you need to not spend anymore money on pimping a turbo that is to small for your setup. Really a 38r is Maxed out at 238s, and at that I wouldn't even run it on that big of an injector.
Op, that mechanic has no clue the 38r will last a long time. I haven't actually heard of one wearing itself out. It's usually killed by to big of injectors and to much back pressure.
Sold 2001 f250 ccsb 4x4 400/400, dual terminators, swamps 80mm bfh, headers, bts and all the usual supporting mods. 715hp fuel only.
06 f250 ccsb king ranch
12 f250 lariat ultimate
dentexpowerstroke is offline
post #10 of 11 Old 06-03-2013, 10:18 AM
Quoted: 822 Post(s)
Not true by any means. This wheel is still relatively new and more R&D is being done by dieselsite as and PHP. See dyno results and beta testing results on here and Dieselsites's web page. One result was easily over 600hp with 250/200's.
