Bigger injectors in stock excursion - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Justin@DP-Tuner
post #1 of 4 Old 06-01-2013, 03:32 PM Thread Starter
Silverbullet 6.0's Avatar
I have an 01 excursion and the injectors are going out its just got a little super chip micro tuner on a tow tune.. I was wondering what brand and how much bigger to go without moding anything else this is a Daily driver and used to pull boat.
Silverbullet 6.0 is offline
post #2 of 4 Old 06-02-2013, 11:19 AM
Roc87's Avatar
Depends on your goals for the Ex. I did stage II injectors from Rosewood knowing I'd have to do something about the turbo (Stage IIs will kill a stock turbo they say, and mine is starting to make some funny noises in boost pulling my toyhauler). I do have custom tunes, and it's still rather difficult to keep it from rolling coal when not pulling, so that's something to consider as well. I do have plans for a GTP38R with a WW once I get the funds back up after doing balljoints and hubs.
If you do not want to really modify much else, I'd get Rosewoods stage I injectors and custom tunes, get rid of that superchips
'01 F250 7.3 PSD 4x4 EC SB. AFE Stage II, Banks 4" turbo-back, turbo housing & IC, Wicked Wheel 2, Rosewood 160cc/80 Single Shot Injectors, Beans Tunes, OilGuard bypass, Riffraff FRX & HPX, Zoodad, Harpoon, '04 18" rims, '07 Front & '08 Rear.
Roc87 is offline
post #3 of 4 Old 06-02-2013, 01:32 PM
Justin@DP-Tuner's Avatar
Quoted: 60 Post(s)
Anything bigger than stock will require custom tunes, so you are pretty limited if you want to keep your current tuner.
Bartlettj54 likes this.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #4 of 4 Old 06-05-2013, 11:09 PM
CSIPSD's Avatar
A nice set of AC injectors and a chip from Power Hungry Performance will work great in your Ex...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
