More upgrade info - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-30-2013, 11:39 AM Thread Starter
camsmell's Avatar
More upgrade info
I recently ordered a gtp38r bb turbo and a 4 in muffler delete I have also been thinking about adding a water meth setup but does anyone know if that will affect my tunning and if it is worth it the setup im looking at is from cool mist thanks
99.5 F250 full force stage II, riff raff frx hpx, T 500, 6637 mbrp stainless 4", DP Tuner, Isspro boost pyro trans, 4" lift john wood vb, 38r, coolant filter, ccv mod, cooling mist stage I, non ebpv pedestal
camsmell is offline
post #2 of 5 Old 05-30-2013, 12:08 PM
Quoted: 3 Post(s)
I was thinking about the same thing, or a larger intercooler. Post up results if you do go the cooling mist route. I dont have stage II's but would still like it down the road when I can afford injectors.
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #3 of 5 Old 05-30-2013, 12:47 PM
Justin@DP-Tuner's Avatar
Quoted: 61 Post(s)
Yes, water/meth would require custom tunes.
I would not say it is required with your setup, but it would not hurt.
Be sure to contact us if you decide to run water/meth so we can get you new tunes.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #4 of 5 Old 05-30-2013, 12:59 PM Thread Starter
camsmell's Avatar
thanks for the info would I just be able to add tunes so I can keep the ones I have now so if I am not using water I still have my original ones
camsmell is offline
post #5 of 5 Old 05-30-2013, 02:00 PM
Quoted: 61 Post(s)
Yep. That would be a great thing to do.
DP-Tuner
Like us on
Justin Bochmann
