Possible water meth setup? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-28-2013, 12:29 PM Thread Starter
jdereu's Avatar
Do It Yourself Water Alcohol Methanol Injection
Does the set up describes on this website seem like a good set up if so what are the pros and cons for the truck described in my signature
Thanks
2000 Ford F-250, Crew Cab Long Bed 4x4, Automatic Transmission, Ts 6 Position, 4" MBRP Exhaust, DIY Intake, Pillar Guages, CCV Mod
jdereu is offline
post #2 of 2 Old 05-28-2013, 10:04 PM
tubular031's Avatar
I would suggest going with some sort of progressive setup. That way you can add more water as the truck works harder. If you use a simple on/off you only get water near the top where you do not spend much time. Also when empty you will hardly use any water. I set mine to start at 6 psi and full at 16. Empty I almost never use water except for the quick sprint to get on the freeway. Pulling will be another story. I have not yet hooked up to the trailer(s) to see how much water I will be spraying.
I went with cooling mist and am happy. Their customer service is awesome.
Just a basic 01 F350 CCLB SRW -Good from a far but far from good
tubular031 is offline
