just purchased a 7.3, some questions please tune in - Ford Powerstroke Diesel Forum
post #1 of 9 Old 05-28-2013, 09:10 AM Thread Starter
Well, I drove 510 miles and bought a 2003 7.3 excursion with 117k miles on it. Has a cold air intake, 4" mbrp exhaust, and the 38r garret turbo upgrade. Supposedly the ecm is stock. However we got 19.1 mpg hand calc. and I wasn't driving for mileage. The thing puts out a decent puff of smoke from a stop and hazes black smoke at wot, which has me wondering if there is a tune in the ecm? Anyways, this vehicle will be pulling our race trailer 80% of its life. What would be a good tuner/programmer to get for towing? The tranny is stock and I don't want to roast it, and I don't want to hinder the mileage it gets, just want some more grunt for towing. I also plan on getting an edge insight for it. I use it on my cummins and like it. Also, anything I shoud watch for with this 7.3?
03 cummins - litte of this, little of that.. Tickled 700hp early 2013
monster50iii is offline
post #2 of 9 Old 05-28-2013, 09:54 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
What kind of cold air intake does it have? as for mileage your probably on the high end for a 7.3l. that coupled with the lack of heavy smoke at WOT makes me think the previous owner had some sort of a program tuner that the pcm still has stored.
I know alot of guys have had success with ts 6 position tuners. I myself have the SCT programmer. I like it i have a tow tune and a 140 hp tune, it came with the truck so i dont know exact specifics but its worked good for what i use it for.
As for things to watch for i would get gauges (boost, pyro, tranny temp) to watch your vitals. Other than that the 7.3 will treat you just as good as you treat it.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 9 Old 05-28-2013, 09:58 AM
sean400's Avatar
Go with a 6pos chip to not roast the trans, definitely get gauges to monitor the vitals. check the cold air intake make sure its not k&n
Early 99 f250 CCSB,8" lift 38.5's,4" back to 5"stacks
Casserly Stage 1's 165cc,E99 Van Turbo w/ Bd Billet wheel, FRx, HPx,TW Tunes,Glow Shift gauges,6637 Intake, Built 4R100 w/ 6.0 Cooler. Harpoon Hutch Mod, Pre pump filter.
2011 f250 XLT CCSB, S&B, H&Sdelete, LiveWire TS w/custom tunes
I'd Rather be Stroking Ahead than Cumming From Behind
sean400 is offline
post #4 of 9 Old 05-28-2013, 12:05 PM
Justin@DP-Tuner's Avatar
Quoted: 51 Post(s)
Are you looking to go with a chip(plugs into the PCM) or a programmer(plugs into the OBDII port)?
We can get you setup with either if you are interested. HERE is a link to all of our custom tuning options.
As for the mileage... That is really good, especially for an Excursion. The black smoke may point to the PCM being flashed or a tune loaded onto the PCM. You could always just as the person you purchased it from.
Let me know if I can help you out with anything.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #5 of 9 Old 05-29-2013, 07:23 AM
Quoted: 6 Post(s)
I went from a Diablo Predator tuner to a PHP Hydra Chip (stores up to 17 tunes, and can accept custom tunes from nearly any tuner out there, except DP) and the difference was huge.
I used the 80 Tow tune this weekend and the trans tuning along made a big difference but the power difference was awesome. Never needed more than half throttle up some big hills, and that was mostly just because I wanted to see what power it had. Kinda funny getting onto the freeway and having people pull out from behind to pass you then you get on it and they just stay behind.
2006 F250 CC/SB 6.0 Diesel
SCT 3015, Straight Piped
2002 F350 CC/SB 7.3 Diesel- SOLD
-PHP Hydra, 6637, Diamond Eye DEP-510215 Muffler Delete, GlowShift Triple Gauge Cluster.
-Plans: JW Valve Body & 6.0 Torque Converter/Cooler
bikeluver43 is offline
post #6 of 9 Old 05-29-2013, 08:32 AM Thread Starter
I was going to look into a dp tuner, tried calling several times with no answer, so I ordered a Pheonix chip with the 6 tunes. What are some decent trans upgrades? I was thinking maybe a torque converter, and different valve body?? I don't need an all out trans, just maybe something that can withstand the task of time with a trailer on it.
post #7 of 9 Old 05-29-2013, 07:01 PM
I just bought a 2002 Excursion that is completely stock and at WOT it does not smoke any color at all blue, white, black nothing is this good or bad?
bad65nova is offline
post #8 of 9 Old 05-29-2013, 10:38 PM
Quoted: 51 Post(s)
Sorry about the no answer. At times, we experience a very high volume of calls. Did you try leaving a message? We usually get back to people as soon as possible if a message is left.
DP-Tuner
Like us on
Justin Bochmann
post #9 of 9 Old 05-29-2013, 10:39 PM
Quoted: 51 Post(s)
No smoke at all if a great thing!
DP-Tuner
Like us on
Justin Bochmann
