best pyrometer setup? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-27-2013, 06:24 PM Thread Starter
whats the best pyrometer setup? bully dog monitor? gauges? i was thinking the bully dog monitor with the pyrometer kit.
blakerugg is offline
post #2 of 11 Old 05-27-2013, 06:30 PM
jesilvas's Avatar
Quoted: 3 Post(s)
I've done gauge pod. Honestly, I'd go with the Edge CTS like most do for 6.0s. Very nice, monitors a ton of parameters, and you just add what you don't have.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 11 Old 05-27-2013, 06:34 PM Thread Starter
they work just as well with the 7.3?
post #4 of 11 Old 05-27-2013, 06:42 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Yea as far as I know. Not a lot who do it honestly. I'd do a monitor system as opposed to true gauges. Like I said, did em, don't care for em anymore.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 11 Old 05-27-2013, 06:54 PM
Macon's Avatar
I have the Insight CTS; I like it. I want a different gauge for boost, fuel pressure, and an extra pyro for tranny temp, but the CTS with add-on EGT does just fine. I want a boost gauge so I don't rely on MAP readings, the extra pyro so I always have good tranny info, and the fuel pressure just to let me know how my pump is doing.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #6 of 11 Old 05-27-2013, 06:57 PM
05_PSD_Erik's Avatar
I, too, am on the side of a digital monitoring solution. For the ~$2-400 an Edge CT/CTS would set you back, you can do a nice quality 3-4 analog gauge setup. With the analog, you will have to wire up for each gauge and then you have the gauge mounting to deal with, pillar, dash, over the mirror, etc. Where with the digital display, you can monitor more than you may ever need, have the ability to view/clear DTC codes and it all fits in a nice package you can mount in the window or wherever you want.
2009 Subaru WRX Premium
Type RS BOV
CAI
Muffler Delete
Had to park it with some real diesel muscle....
05_PSD_Erik is offline
post #7 of 11 Old 05-27-2013, 09:47 PM
Justin@DP-Tuner's Avatar
Quoted: 63 Post(s)
Our Infinity monitor/programmer can monitor EGT with the use of an add on thermocouple. It will also tune, monitor all generic and Ford enhanced parameters that your PCM can see, datalog, and run diagnostic tests(KOEO/KOER, injector buzz, cylinder contribution, glow plug).
You can check it out HERE if you are interested.
Feel free to contact me with any questions you may have.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #8 of 11 Old 06-07-2013, 02:55 PM
Quoted: 14 Post(s)
Happy with my Isspro gauge pod set up. Wasn't a big deal to install, easier to read at a glance.
ttyR2 is offline
post #9 of 11 Old 06-07-2013, 03:04 PM
Joel's Avatar
Quoted: 10 Post(s)
I have both
I would post pictures, but I don't think I can from this iPad
If I had to chose, the monitor is probably the better option all round.
I like the CS because it's smaller and takes up less space.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #10 of 11 Old 06-07-2013, 03:18 PM
I own a e99 7.3 and the bully dog ECONOMY monitor had major compatibility issues so i returned it(I run a ts 6p so i did not need the bully dog tuner/monitor). I decided to buy a column boost gauge and am going to wire in warning light for the trans. Pyro i am purchasing 2 of these(1 for each bank):
Diesel Engine Fast Resonse EGT Exhaust Gas Temp Probe Digital Pyrometer Kit | eBay
I personally do not like the look of gauges all over i feel its overdone, the monitor is very clean look if you want to monitor more than 2 things imo. Just be careful when purchasing monitors that plug directly into obd2, if the ecu doesnt read it from the factory you will need to ALSO BUY a docking station and pyro kit. Good Luck!
PlimptonJr is offline
