Coolant filter mounting??? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-21-2013, 04:25 PM Thread Starter
I started it in another forum some how by accident.
http://www.powerstroke.org/forum/gen...ientation.html
Can filter be mounted horizontally without filter contaminants draining back into engine?
2011 CCLB DRW 4X4 bone stock, SOLD!
Multiple 99-03 in pieces, will have one running soon!
ande6009 is offline
post #2 of 6 Old 05-21-2013, 06:58 PM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
The 6.7 guys are probably scratching their heads on that one wondering where there's any room if at all. I personally wouldn't because of the mess when changing filters and the negative stresses placed on the box (not sure where you specifically are mounting). I wouldn't mount anything to the stock box. Vibration and gravity could foil the whole operation depending on how you mount up.
Google is your friend here: Google
Here's a great thread with some answers: Coolant filter question
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #3 of 6 Old 05-21-2013, 09:34 PM
Eco Taxi's Avatar
x2 on not mounting horz due to mess aspect. I got the the dieselsite coolant filtration. I know plenty of people who have made their own thats identical to mine (same concept). works great. I got ball valves before and after mine to cut off coolant to it for changing
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Eco Taxi is offline
post #4 of 6 Old 05-22-2013, 01:26 AM
CSIPSD's Avatar
Mines been mounted to the AFE intake box for years, filter sitting sideways. No issue at all.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #5 of 6 Old 05-22-2013, 07:03 AM
Eco Taxi's Avatar
Interesting. Live and learn
Kyle
Eco Taxi is offline
post #6 of 6 Old 05-22-2013, 07:25 AM Thread Starter
Thanx for the boost of confidence. I am going to use the port in the waterpump just under the upper hose outlet, If it did flow backwards it would go right into waterpump and that might not hurt but it sounds.....not good anyway.
ande6009 is offline
