Granatelli's Fuego Programmer - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-06-2008, 03:36 PM Thread Starter
Northwest Stroker
BigRed02's Avatar
Any opinions or anyone running this in their rigs? Seems like a cool deal if you had more than one rig. The one being driven for the day can use the tunes. About a 3-5 min vid on it.
How To Spice-Up Your Ford Powerstroke - TruckWorld TV Videos
2003 6.0L Ex Limited
Dieselsite Coolant Filter
Fully Bulletproofed
2002 7.3L F-250 4x4
AFE Stage 1
4" Turbo back Diamond Eye
Zoodad
Foil Delete
Auto Meter "Carbon Fiber" Gauges
2003 Suzuki M109R
Stock...for now
BigRed02 is offline
post #2 of 6 Old 03-08-2008, 12:54 PM
Ole White
bigwhite7.3stroker's Avatar
Don't know bout that one but you have a 7.3 and the best for the 7.3 is a chip not programmer from either DP-Tuner or Tony Wildman many many more here on the ORG will tell you the same these chips are custom burned to your trucks mods and your needs not just a generic off-the-shelf chip
Looking for 05-07 front end with Harley Lights
bigwhite7.3stroker is offline
post #3 of 6 Old 03-08-2008, 02:37 PM
I have the Fuego for my truck (04 6.0) and it's pretty sweet.* My friend also bought two of them for his f350 and his wife's Excursion (both 7.3s) and he said they were both "ridiculous" after being prgrammed.
2004 F250 CC SB 4x4 Lariat
WIX intake with zoodad mod
(05 & up) Innovative Diesel intake elbow with butterfly valve manifold removed
4" SS T-Back no kitty exhaust
SCT X3 w/ I.D. Custom Tunes
Gauges: EGT, Boost, Tranny Temp
Pace Edwards bed cover / B&W Gooseneck Hitch / Linex
DieselSite coolant filtration system
DC Power Engineering 250A Alternator
Submariners do it deeper!!!
ShawnCT450R is offline
post #4 of 6 Old 03-09-2008, 05:20 PM Thread Starter
Northwest Stroker
BigRed02's Avatar
Yeah TW is a definate want. And I would feel like after I get one. I was looking in to buying an X for the wif and I thought that having one of these things would be different.
Hey Shawn are you able to use yours for multiple vehicles or do you have to buy a certain SD card, or whatever it is that he shows popping on the inside of that thing?
Fully Bulletproofed
2002 7.3L F-250 4x4
AFE Stage 1
Zoodad
Foil Delete
2003 Suzuki M109R
Stock...for now
BigRed02 is offline
post #5 of 6 Old 03-09-2008, 05:36 PM
Chpis will blow programmers away anyday. DP or TW are both very good. My truck is tuned by DP. Chips are also adjustable on the fly and are usually much less expensive and produce much more power. If you decide to make changes to your truck they can be custome tuned for the changes. Such as injectors, if you got rid of the split shots and bought single shot injectors ( which are much better ) you wouldn't be able to tune them with a programmer.
Buy now and buy right, buy a chip
Performance Oil Products is offline
post #6 of 6 Old 03-09-2008, 07:57 PM
The fuego is able to program a bunch of different vehicles. It is vin-locked to the one you have currently programmed. You can return to stock and program something else if you like. I haven't seen JR put a SD card in it. Not sure on that one. I know you don't need it to program other vehicles though.
