Help with safe towing power. - Ford Powerstroke Diesel Forum
post #1 of 21 Old 05-19-2013, 01:28 PM Thread Starter
International25's Avatar
Ok I have a 2001 f 350. 333,986 miles. not worried about miles she runs great and ill certainly rebuild her. Used at least every other day to tow loads between 10,000lbs and 16,000lbs. I'm going to rebuild my turbo and upgrade the wheel with a riffraff or wickedg2 whichever I decide is better. But I'm also getting the head studded in case of future upgrades. I'm upgrading fuel system, injectors, hpop. But I want to know other things I can do to get safe towable power. I've thought about compound turboing. The only upgrades so far are straight pipe exhaust, cold air intake, and edge evolution. Trying to make my mind up before I order a bunch of stuff and not like it.
LONG LIVE THE POWERSTROKE
International25 is offline
post #2 of 21 Old 05-19-2013, 01:32 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
What are you doing to take care of the drivetrain of the truck? New/better clutch? Upgrade tranny cooler? One of them fancy pumpkin covers that holds extra? Upgraded brakes? Bigger badder inercooler? If your towing everday might wanna look at helpin out more than just the motor.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 21 Old 05-19-2013, 01:35 PM
kendallcschm's Avatar
Send a message via Skype™ to kendallcschm
i'd agree with that.. i know on the 6.0Ls the F-550s had a bigger trans cooler and i'd hope the 7.3L SDs would be the same.. so you might wanna throw that in there.. and certainly a bigger intercooler! i believe Mishimoto makes a nice one and banks makes one for the 6.0L i'm not sure about the 7.3L and what about exhaust to keep EGTs down? exhaust as in 4" not just a straight pipe
2007 Ford F250 Lariat 6.0 Powerstroke
mods:
Banks Ram air
Sinister Coolant Filter
Swamps 48V FICM with PHP Atlas 40
B&W turnover ball hitch
EGR Delete
Diesel Site Intercooler Boots
SCT livewire TS 5015 w/IDP custom tunes
Agressive street, Tow W/jake brake, Economy
Other rides:
2010 Ford Explorer 4.6 24V V8
1999 Ford Mustang Cobra 4.6 32V V8
Mods:
JLT True CAI
Smoked Heads/tails
kendallcschm is offline
post #4 of 21 Old 05-19-2013, 01:40 PM Thread Starter
Ok lol don't jump the new guy. I have installed a dusl disc south bend clutch and upgraded brakes. Have not upgraded intercooler yet. Guess I should have said that but I was asking for power.
post #5 of 21 Old 05-19-2013, 01:45 PM Thread Starter
Ill look into a new intercooler
post #6 of 21 Old 05-19-2013, 01:47 PM
sprksonu's Avatar
6.0 intercooler and trans coolers are a cheap and effective upgrade for the 7.3
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #7 of 21 Old 05-19-2013, 02:03 PM Thread Starter
I have heard the 6.0 intercooler is a direct bolt on replacement? How true is that? Lol I actually have a 6.0 intercooler in the garage we took off one of the wrecked work trucks. So If it would bolt up fairly easy I may start on that tonight.
post #8 of 21 Old 05-19-2013, 04:02 PM
I just did beans stage one injectors, and tuning, diesel site waste gate controller, ww2 and boost fooler. Also upgraded uppipes. I can slam over 35psi and barely get over 1200on the egts. The BTS let's it all get to the road. Awsome set up for towing.
01 F-350 reg cab srw 7.3
Important stuff:
Beans stage 1 injectors, Beans 6 position chip
Dieselsite ww2, boost fooler, wastegate controller
gauges, upgraded up pipes,
afe intake, 4" flow through muf w/turn out
BTS transmission, 6.0 cuuuler
35"toyo mt on 18" black kmc addicts
06 F-350 cc srw 6.0 lariat
build being planned...starting with the cab off
frashdog is offline
post #9 of 21 Old 05-19-2013, 05:09 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Towin heavy what about maybe water meth set up?
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #10 of 21 Old 05-19-2013, 05:18 PM
2000-7.3L's Avatar
Feedback Score: 10 reviews
My truck tows 10K no problem! It tows my company trailer!
Well shouldnt say that, im getting the Wicked Wheel gen 1, and my chip to help improve MPG and add a little more under the hood when towing.
2000-7.3L is offline
