Wicked wheel was alittle too wicked :( - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-14-2013, 03:52 PM Thread Starter
case340's Avatar
Well about 4 weeks ago I got my ww2 in and installed it, did it the right way and took the turbo out and split it instead of using an impact, ran great after I got it all back together, absolutely loved it. Well last Friday the whole turbo went boom took it to the shop and I could move the shaft up down and all over the place and when I had put it all back together after the install there was no shaft play.. What could have caused this? I have a 38r now getting put on this week
case340 is offline
post #2 of 12 Old 05-14-2013, 04:01 PM
2000-7.3L's Avatar
Feedback Score: 10 reviews
Ummmmmm......... This could be bad!
Sent from AutoGuide.com App
2000-7.3L is offline
post #3 of 12 Old 05-14-2013, 04:48 PM
Quoted: 134 Post(s)
Feedback Score: 3 reviews
Yea but,,, there's supposed to be play "up down and all over the place"...
IF, when you put it together it had No Play, you did something wrong
I have no idea how, or why, but without play there is No Room for the lubricating oil it needs. Did the wheel have so much play it dragged on the housing? If not, that sounds perfectly normal to me.
NoRalPh is offline
post #4 of 12 Old 05-14-2013, 04:53 PM
2000-7.3L's Avatar
Getting nervous about doing my wheel now! What could have gone wrong, seems straight forward
post #5 of 12 Old 05-14-2013, 08:08 PM
timmyboy76's Avatar
sounds similar to what i had done, but with a gen 1 w.w. I THOUGHT the wheel was threaded all the way. A little time later, BOOM, turbo went. Broke the shaft, sent chunks into the IC..you get the picture. Sit'n there, scratch'n my head, as to why this happened.
Well, it wasnt until i rebuilt the turbo, that i noticed something. I noticed on the turbo i rebuilt, that the wheel "sat" 1/8-3/16 down, past the shaft, meaning, the shaft protruding that much out the center of the wheel. I go and look at the w.w. still on the broken shaft and yup, that wheel sitting flush.
What i think/know happened, is when i installed it WITH an impact, it just did not "suck" the bushing clamp rings into their respective spots, thus, leaving enough gap to eventually cause havoc.
Not saying this is your case, but it sure the heck was mine...
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #6 of 12 Old 05-15-2013, 12:30 AM
dentexpowerstroke's Avatar
You checked torque when you installed? I've seen a lot of turbos blow from over torqueing wheels.
Sold 2001 f250 ccsb 4x4 400/400, dual terminators, swamps 80mm bfh, headers, bts and all the usual supporting mods. 715hp fuel only.
06 f250 ccsb king ranch
12 f250 lariat ultimate
dentexpowerstroke is offline
post #7 of 12 Old 05-15-2013, 12:57 AM
Justin@DP-Tuner's Avatar
Quoted: 47 Post(s)
A little bit of side to side play is okay/normal. What you do not want is any in and out play. That indicates a problem.
As stated above, if you tighten it up with an impact or torque it too much, you could have damaged the shaft which would eventually lead to complete failure.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #8 of 12 Old 05-15-2013, 04:24 AM
goats's Avatar
Quoted: 2 Post(s)
Could have been a balancing issue. People really should have them rebalanced after a new wheel is installed.
goats is offline
post #9 of 12 Old 05-15-2013, 12:19 PM Thread Starter
case340's Avatar
It had in and out play and a groove where it cut into the housing..
case340 is offline
post #10 of 12 Old 05-15-2013, 12:38 PM
Quoted: 47 Post(s)
Yeah that kind of play is no good.
DP-Tuner
Like us on
Justin Bochmann
