need wiring help!!! - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-13-2013, 07:53 PM Thread Starter
thumper1989's Avatar
need wiring help!!!
im trying to wire up my banks trans temp gauge but cant figure out how to connect the sensor to the wire that goes to the gauge. instructions say something about a lock nut but there isn't one it just looks like the head of a nail kinda..... please someone help ive been searching forever trying to figure this out
thumper1989 is offline
post #2 of 10 Old 05-13-2013, 08:05 PM
Quoted: 3 Post(s)
do you have a picture of the back of the gauge? is it new? I worked on one a while back but dont remember how there set up.
2002 F-250 XLT 4x4 offroad extended cab short bed
2000 model 7.3L diesel with forged rods
4-4.5in down pipe 5in back exhaust, 6637 filter, backup camera, gauges,
Ky CCDW Instructor
ken6881 is offline
post #3 of 10 Old 05-13-2013, 08:31 PM Thread Starter
No not the connection to the gauge the connection at the thermocouphink its called
post #4 of 10 Old 05-13-2013, 08:58 PM Thread Starter
The instructions say to crimp a ring connector to the blue wire.. ok got that then remove a non exsistant lock nut on the sensor.... thats where im lost
post #5 of 10 Old 05-13-2013, 09:16 PM
Quoted: 3 Post(s)
The only lock nut would be the one that goes around the probe and tightens to the part that screws in the manifold.
Ky CCDW Instructor
ken6881 is offline
post #6 of 10 Old 05-13-2013, 10:30 PM Thread Starter
Ok so how do i attach the wire to the back of the sensor? Lets assume i have the right parts...
post #7 of 10 Old 05-14-2013, 07:47 AM
DieselManor's Avatar
Sounds like you need a ring terminal. It gets crimped onto the sensor ware, and then you put it over the threaded pin on the sensor and then tighten the nut over the top. I recommend that after you make this connection you apply some RTV silicone over the entire connection to keep it free from water and road debris. If you look at the picture below, you can see 3 different size ring terminals in our kit. These are non-insulated, but there are insulated ones out there. We use these non-insulated ones for grounding, so they don't need to be insulated. You should use an iunsulated version.
I found a pic:
you can get these terminals at RadShack and just about anywhere. Make sure you get one w/ the ring that fits over the threaded pin snug and not too loose.
Hope that helps.
David Murphy
DieselManor is offline
post #8 of 10 Old 09-13-2013, 09:34 PM Thread Starter
Back on after being gone a while... soddered it... works fine.
post #9 of 10 Old 09-13-2013, 11:53 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
You soldered the wire straight to the sensor?
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #10 of 10 Old 09-14-2013, 06:29 AM
Macon's Avatar
I would too. What he described sounds like a solder pin to me. Glad to hear you got it fixed up.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
