good idea? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 05-10-2013, 09:46 AM Thread Starter
good idea?
on my 2001 7.3 if i put 4 inch exhaust k&n cold air programmer wicked wheel turbo upgrade 6.0 tranny cooler and stage 1 injectors will that be in the safe zone where i wont be flirting with problems? yes or no answer will do if no what is? also any idea on how much this cost? need to find out how much to set aside
Shredda is offline
post #2 of 9 Old 05-11-2013, 11:12 AM
Wannabitawerm's Avatar
Don't go k&n. look at the 6637 DIY. Waaaay cheaper and flows better. As far as cost, couldn't tell you as there are a lot of options. Do your research, make a list, gather prices. That's the best way.
Sent from AutoGuide.com App
Wannabitawerm is offline
post #3 of 9 Old 05-11-2013, 11:12 AM
Also, intake, exhaust, and gauges should be priority number 1.
post #4 of 9 Old 05-12-2013, 03:13 PM
dentexpowerstroke's Avatar
6637 flows cleaner. the kn filter will allow to much thru which will in turn dust the motor and trans. Also when you say programmer what do you mean? I wouldnt run anything other than custom tunes unless you can rebuild your own trans for very cheap. Stock turbo is really maxed out with the stock injectors, the wicked wheel won't change the fact that the turbine side is to small. You are lookong at a couple thousand for everything.
Sold 2001 f250 ccsb 4x4 400/400, dual terminators, swamps 80mm bfh, headers, bts and all the usual supporting mods. 715hp fuel only.
06 f250 ccsb king ranch
12 f250 lariat ultimate
dentexpowerstroke is offline
post #5 of 9 Old 05-12-2013, 04:55 PM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
[QUOTE=dentexpowerstroke;5276345]6637 flows cleaner. the kn filter will allow to much thru which will in turn dust the motor and trans./QUOTE]
I may have missed something here.
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #6 of 9 Old 05-12-2013, 08:41 PM
No, i was half asleep when I typed it lol. Meant turbo, I am to used to typing trans on my phone. thanks for the catch.
post #7 of 9 Old 05-12-2013, 10:13 PM
Justin@DP-Tuner's Avatar
Quoted: 57 Post(s)
As stated, look at other options besides the K&N. With good tuning on that setup, yes you are still in the safe zone. Gauges are vital before adding tunes or injectors, so factor that in as well.
We can get you setup with the gauges, tunes, and injectors if you are interested. Shoot me an e-mail or PM for pricing.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #8 of 9 Old 05-13-2013, 03:07 AM
I'm still very new myself to having a diesel but after reading all the different advice I have gotten from this site my truck runs amazingly. 6637 intake, 5inch MRBP, and DP Tuner's Infinity gauge and tuner combo my truck runs like a bat out of hell. For the intake and exhaust system I was at about $400, the tuner was about $1100 but it was more then worth it.
EODphillips is offline
post #9 of 9 Old 05-13-2013, 08:31 AM
Quoted: 57 Post(s)
Great setup you have there. Glad you like it.
DP-Tuner
Like us on
Justin Bochmann
