evbp
So where do I find the wires and what color are they? I can't seem to fibd a write up
what excatly are you trying to do. are you trying to unhook it or what. if you want to unhook it, its on teh front side of teh turbo onteh bottom. there is a little metal clip holding the 2 wires in there. simply lift up on teh clip and pull teh plug out and its unhooked.
Sorry!! I want to beable to controll it with a switch. I am sick of heiring it every day.
I would just unplug it, mine has been unplugged for years and the truck warms up just fine and dandy the plug is a 2 wire connector on the turbo prdistal, its kida tough to reach but its as simple as unpluggin it and the EBPV wont ever come on again
I would like to use it as a brake while towing. Is it just 12vdc that runs it?
i unpluged my wastegate but that would be a good idea to make a jake out of it. let me know how you do it
if you could simply put it on a switch and use it as a brake im sure someone would have already done that... Im pretty sure it runs on temperature so to make it come on you would have to fool the system thinking the engine is too cold to make it come on. Correct me if im wrong, just my 2 cents.
I know it has been done I have seen the posts. I just can't find it.
its not the wastegate you unplugged, its the Exhaust Back Pressure Valve, unless your referring to the red tube going to the wastegate accuator?
I will work it out his weekend and let you know
