Turbo Help???? - Ford Powerstroke Diesel Forum
Old 02-25-2008, 05:24 PM
Turbo Help????
Was wondering if anyone would recommand the industrial injection phat stroker turbo for my 03 7.3. The shop i was talking 2 recommands it but is it better then the garret power max BB. Some please give me some advise?
Old 02-25-2008, 05:30 PM
I personally have not ran a phatshaft or know anyone that has so I cannot comment on that turbo. I will tell you the Garrett BB has been around for a long time and had pushed 500+ HP . At around $1600 for the Garrett I would be will to bet its cheaper too. The Garrett is also a drop in turbo meaning you don't have to change anything else out on your truck. I'm not sure thats the case with the Phatshaft.
Old 02-25-2008, 05:33 PM
what are your HP goals and what are your current mods??
Old 02-25-2008, 05:34 PM
International Threat
Turbonetics BB or Garrett 38R seem to be the most common upgrades for medium power...
between 350-550 rwhp.
Old 02-25-2008, 05:38 PM
I got bully dog power pup with monitor 4inch exhaust and afe stage 2 intake. Wanna be running around 400hp 2 the wheels wanna do injectors 2 and wanna do the highest injector hp on the stock oil and fuel system...
Old 02-25-2008, 05:40 PM
Stage 3 hybrids with SMALL NOZZLES and DETUNED will easily get you 400 rwhp...
BUT you're going to have to loose the power pup and get custom tuning.
I suggest DP TUNER or Tony Wildman.
400 hp at the wheels will eventually break your PMR rods... so you should start saving for a new short block in the mean time.
Otherwise you'll end up like me -->
Old 02-25-2008, 05:42 PM
if your looking at over 500 HP i would reccomend a different rout than the GT38......300-400 (at the wheels) it can be a good option though...
Well whats a safe hp on the stock block?
Old 02-25-2008, 05:44 PM
38R's have pushed 500+ on fuel but is out of it's map range.
500+ also costs 10+ grand though, especially for a PMR block...
Old 02-25-2008, 05:45 PM
Well whats a good 8 settings u can have on that dp tuner thanks for all the help?
