ISSPRO fuel pressure sensor - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-05-2013, 10:53 AM Thread Starter
Lmgrpowerstroke's Avatar
the gauge is a ISSPRO EV2 series
Ive had my fuel pressure gauge for roughly a year now and my second sensor just took a crap. the first one they sent me a new one free, but has anyone else had this problem.
seems alittle outrageous to go thru 2 sensors in a year.
01 350 Commonrail
08 250 6.4 deleted, singled, tuned, other goodies
Hydrographic dipping
Nostalgia Works Imaging
www.nostalgiaworksmd.com
Lmgrpowerstroke is offline
post #2 of 7 Old 05-06-2013, 08:52 PM
tubular031's Avatar
hmmm I have had mine for probably 2.5 to 3 years now and mine sits at 75 psi most of the time and hot VO going by it.
Just a basic 01 F350 CCLB SRW -Good from a far but far from good
tubular031 is offline
post #3 of 7 Old 05-06-2013, 09:19 PM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 235 Post(s)
Ive had mine for over a year now, no issues with the sensor
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW See my visitor messages for my mods
Edge Insight & SCT X4 FOR SALE
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is online now
post #4 of 7 Old 05-10-2013, 06:44 AM
DieselManor's Avatar
Where do you have the sensor located? Is it in the back side of the fuel bowl? You might try using a needle valve like the one below to tame down any pulses getting to the sensor. I've found that it helps prolong their life. The sensors are the weakest component on any ele. fuel pressure gauge.
Specialty Fittings at DieselManor
David Murphy
DieselManor is offline
post #5 of 7 Old 05-12-2013, 05:10 PM
Quoted: 235 Post(s)
I did forget about the one, i wouldn't even call it a problem, thing I would see, when on a long trip, during the winter, especially if it was snowing.... During extended drive times, on the highwy, either I wouldn't catch it acting up, or I would catch it, the gauge would steadily start making its way up, with some fluctuation, until it would top out. It would stay there, until I got off the highway, then it would almost immediately return to normal. The only thing I can think it would be is needing the needle valve. Anybody else seen or heard of this phenomenon? Thoughts? (BTW, I got this gauge and mount from you David)
post #6 of 7 Old 05-14-2013, 07:53 AM
Just an update, ISSPRO has new sensors now. We have them on order. They have a new part # and these sensors are more robust than the older ones and should last much longer.
ISSPRO R89145 HD Electric Fuel Pressure Gauge Sensor at DieselManor
David Murphy
post #7 of 7 Old 05-19-2013, 08:10 AM Thread Starter
my sensor is in the regulator.
01 350 Commonrail
