Upgrade - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-03-2013, 06:42 PM Thread Starter
Redlazer's Avatar
Upgrade
I'm needing a new clutch slave plate Pressure plate in my truck. Since I need these parts I want to upgrade them to heavier duty parts than stock. Can someone give me who makes heavier duty parts for my tranny?
early 99 Red F-250 XL SD, 7.3L, 6-speed manual, Extended Cab, Long Bed, 4x4 Off Road, and Reflexxion Cowl Hood, Ion Alloy 183 wheels, 05 headlights with 6000k AC HID kit, and led turn signals, Ford ASI filter w/ zoodad mod and foam sleeve, TS 6 position chip, Auto Meter Z series Boost and EGT gauges, and straight pipe oem exhaust. .
CAROLINA GRAY BOY
Redlazer is offline
post #2 of 4 Old 05-06-2013, 06:17 AM
Quoted: 30 Post(s)
South Bend or Valair.
What do you need?
A pressure plate, flywheel or clutch disc? Or all of the above?
Not many people replace one without the others. But if you want to i have a flywheel and pressure plate from Valair that have about 10K mile son them inn great shape. I put a south bend in my rig cause i sprung an oil leak off my HPOP loosing 2 gallons every 20 miles thenopil seeped into my bellhousing and saturated the disc. Disc is garbage but everythign else is almost new. Let me know and i can send pics.
CarportMechanic is offline
post #3 of 4 Old 05-06-2013, 09:50 AM Thread Starter
Redlazer's Avatar
I want all of them. So I will not have any problem for a long time.
CAROLINA GRAY BOY
Redlazer is offline
post #4 of 4 Old 05-06-2013, 10:07 AM
Quoted: 30 Post(s)
I would reccomend South Bend Clutch.
I put in a 400 HP rated one and really like it. I only have minor mods done and am not close to 400 HP but plan to upgrade in teh future and if a clutch can last 200K i dont wanna replace it in the future when i do upgrade.
The south bend has a semi soft pedal and is smooth when towing and all around driving. If i feel like getting on it and dumping gears it works even better i think. Great clutch and i hope to get many years out of it! Only put about 5K on my rig each year tho so it should last a loooooong time!
Good luck!
