1.00 a/r vs 1.10 TURBOS - Page 2 - Ford Powerstroke Diesel Forum
post #11 of 23 Old 02-25-2008, 09:25 AM Thread Starter
myredtruck's Avatar
ok tried the chip in the old 350,000 mile stroker and she smokes like a sun of a gun. looks like the chip is good. must be a bad lift pump in the other one. dont matter its going to auction. that chip doesnt do as much as i expected a chip to do. i mean it works just not as big a gain as i thought.
is it worth switching out that 1.10 housing turbo into my truck? or is it more work than needed being as it might only be a housing and the rest stock?
myredtruck is offline
post #12 of 23 Old 02-25-2008, 11:44 AM
CSIPSD's Avatar
The 1.10 turbo is from a early 99, it will not fit on a late 99 truck.
There is no lift pump on a PSD... There is a fuel pump and a HPOP (high pressure oil pump). Fuel is injected when pushed by the HPO. The chip could be doing many things, but first off is the early 99 trucks had a smaller HPOP and chips would tax them.
If you put that chip in another year truck what year was it?
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #13 of 23 Old 02-25-2008, 11:46 AM
CSIPSD's Avatar
Originally Posted by myredtruck View Post
service engine soon light comes on just for a second when you nailed it. only with the chip though. i also forgot to mention the lift pump is wining . i can see it affecting it but cant see it being the whole cause
Pull the codes, it could be an overboost code or (most likely) an ICP code... 1211 would be my guess
Originally Posted by 06Blackmamba View Post
sounds like the pump won't supply the fuel it needs. try it on those othere trucks see what happens. also make sure that chip is for that your of truck and not the 96 97 trucks lol. get the product number and look it up see what you find~
There is no lift pump, the HPOP might not be keeping up with the demand, but that has nothing to do with the fuel getting to the injectors.
Joe
CSIPSD is offline
post #14 of 23 Old 02-25-2008, 01:12 PM Thread Starter
myredtruck's Avatar
ok that would make sence on the turbo exept the 1.10 is on a early 99(04/08) but my truck is also a early 99 (06/98, cant believe they can call that a 99) and its got a 1.00 turbo housing?
the truck i tried the chip in was a late 99
post #15 of 23 Old 02-25-2008, 01:16 PM
CSIPSD's Avatar
The 1.10 will ONLY fit an early 99, the later turbo will ONLY fit a later build...
The compressor housing is not nearly as important as the exhaust housing anyway.
Joe
CSIPSD is offline
post #16 of 23 Old 03-04-2008, 03:30 PM Thread Starter
myredtruck's Avatar
ok i just started tearing down my motor and it has a 02 sticker on the passenger side valve cover. with that and the turbo being a 1.00 not a 1.1 it sounds to me like the motor and turbo was replaced. is that a correct assumption or could they have just replaced the valve covers? and is this going to jack with my electrical for things like a chip or what not?
post #17 of 23 Old 03-04-2008, 03:32 PM Thread Starter
myredtruck's Avatar
p.s i sold the other two trucks so now its just mine thats got the blown headgasket i just started. so im not worried about the other trucks issues
post #18 of 23 Old 03-04-2008, 03:33 PM
CSIPSD's Avatar
Please start over again... I have no idea what year your truck is, or what the problem is... lost.
Joe
CSIPSD is offline
post #19 of 23 Old 03-04-2008, 05:13 PM
binder man's Avatar
couldn't the 1.10 housing be a garrett BB turbo? just wondering but that could explain no smoke?
Luke
Early 99, regular cab, Six Speed, Wildman Tuned, Red wastegate line MIA, muffler MIA, Isspro EGT/Boost, DIY Tymar, EBPV Switch, a slipping South Bend, 2.5" leveling kit, 35x12.5 BFG All-Terrains, 16.5" American Racing wheels SOLD
2004, regular cab Six Speed Edge Juice with Attitude, Eagle alloy wheels
binder man is offline
post #20 of 23 Old 03-04-2008, 05:16 PM
CSIPSD's Avatar
Garrett BB comes with a 1.00 compressor housing and a 1.00 exhaust housing.
Joe
CSIPSD is offline
