6.0 Cooler vs. TruCool - Ford Powerstroke Diesel Forum
post #1 of 9 Old 05-03-2013, 08:57 AM Thread Starter
It appears from RockAuto I can get a 6.0 cooler for just over $200. I understand it is about $70 more expensive than the TruCool, and is supposed to be a direct replacement for the 7.3 cooler.
Thoughts on which one to go with? I like having a direct replacement versus another piece of equipment.
Does the 6.0 work better by itself, or the TruCool with the 7.3 cooler in series?
Thanks in advance....
2002 F250 CC SB 4x4 7.3L
186K Miles
CCV Mod
Fluidampr
PHP Hydra
RiffRaff FRx
AFE Stage 2
Wicked Wheel 2
Adrenaline HPOP
Evans NPG Coolant
Aeroforce Interceptor
Mishimoto Intercooler
6.0 Transmission Cooler
Red Head Steering Gear
4" Turbo Back Magnaflow
International Bellowed Up-Pipes
Dieselsite Legendary Transmission
2 Corinthians 5:15 - "and He died for all, so that they who live might no longer live for themselves, but for Him who died and rose again on their behalf"
PreciousMetals is offline
post #2 of 9 Old 05-03-2013, 09:09 AM
layson's Avatar
Quoted: 82 Post(s)
Use the 6.0, it bolts right in and easy to install just got to get a couple fittings and some hose. It is huge compared to the stock cooler. Spend the extra money and go for it.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #3 of 9 Old 05-03-2013, 01:25 PM
The question is who makes the 6.0L cooler that you're finding on Rock Auto. From what I've seen it says "Various MFR", so it is not OEM. Does anyone have experience with a Dorman or other 6.0L transcooler for comparison to the OEM?
2000 F350 4X4 CCSB w/ 7.3 and 4R100
PIS 175/80, Adrenaline HPOP, 4" Exhaust, 6637 Filter, CCV Mod, Leveled Front, 315/75/16 Goodyear Duratracs
Devil Car is offline
post #4 of 9 Old 05-03-2013, 01:29 PM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
Ford 6.0L Powerstroke OEM Transmission Cooler
this is where I got mone with the install kit...
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is online now
post #5 of 9 Old 05-03-2013, 02:14 PM
sprksonu's Avatar
here is a oem from sunrise ford a vendor on here most of the time shipping is free or dirt cheap 2005 FORD F-250 SUPER DUTY Parts -
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #6 of 9 Old 05-18-2013, 07:41 PM
Chapter Director
freeride707's Avatar
Ive had both and im currently running a 6.0 cooler for obvious reasons.
Tru cool and stock cooler i was running around 180* i now run down around 140*
both were with the BTS trans and similar conditions. In talking to the trans builder himself the flow of fluid is much better with the 6.0 cooler due to the larger lines also the oem cooler is huge. well worth it
E99 F250 7.3l CC SB 4x4 Lariat,8.5" lift, dual reservoir shocks toyo my 37's gear alloy 20x12's,TW chip,5in exhaust,DIY intake,BTS trans,HPX, frx gauges,Powerslot rotors w/hawk pads,Tint,08 emblem vents,Custom paint,05 Harley front w/ custom grill, shaved 08 step gate and tinted tails, spray-in bedliner
WCS Assistant Director
freeride707 is offline
post #7 of 9 Old 05-19-2013, 05:07 PM
There is a reason BTS pushes the the 6.0 cuuuulers.
01 F-350 reg cab srw 7.3
Important stuff:
Beans stage 1 injectors, Beans 6 position chip
Dieselsite ww2, boost fooler, wastegate controller
gauges, upgraded up pipes,
afe intake, 4" flow through muf w/turn out
BTS transmission, 6.0 cuuuler
35"toyo mt on 18" black kmc addicts
06 F-350 cc srw 6.0 lariat
build being planned...starting with the cab off
frashdog is offline
post #8 of 9 Old 05-19-2013, 05:33 PM
This is useful information! I have been going back and forth between the 6.0 cooler and the Tru cool. Up until this post, I had not seen an actual comparison with data, just a lot of opinions.
This post here seals the deal for me.
post #9 of 9 Old 05-20-2013, 07:48 PM
Chapter Director
the tru cool was a total waste didnt even drop temps much more than the stock cooler, when i put the 6.0 cooler on wow what a difference, im not even exagerating i can tow 10k through the hills in 100* heat and not have a tranny temp over 185* thats with big tires and stock gearing...
