FPR shim HELP! - Ford Powerstroke Diesel Forum
Old 02-23-2008, 07:22 AM
Send a message via AIM to hartman99
Angry FPR shim HELP!
I tryed the FPR shim the other day with a BB and i got pressures of 100psi or over so i took it back to stock.Now it looks like the vavle for the water separator is leaking but im not sure. but its leaking pretty good out of some where.Any ideas on where i should start?
Old 02-23-2008, 07:26 AM
Look at this schematic and it might help you narrow down and identify where your leak is coming from:
Powerstrokeshop.com
Old 02-23-2008, 12:02 PM
that short time at 100 psi probably blew out the drain valve o rings try checking there or possibly the big o ring around the fuel filter lid.
Old 02-24-2008, 02:42 PM
Yea it was the o-rings on the vavle.Thanks!
