Regulated return. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-01-2013, 06:05 PM Thread Starter
superjoey03's Avatar
Regulated return.
Just curious if its necessary to have 3/8 hose with -6an fittings for the kit I'm building. The banjo bolts are going to be drilled out to 1/4" and the fittings going into the head are 1/8"npt. So in the way I see things -4an fittings and hose would be just fine. Any input would be really appreciated as I'm trying to get my parts ordered ASAP
superjoey03 is offline
post #2 of 4 Old 05-02-2013, 05:55 PM Thread Starter
Bump
post #3 of 4 Old 05-05-2013, 06:47 PM
the1laf's Avatar
Good Luck & a Bump man...
I wish I could help but unfortunately I'm in the same predicament.
Here's my thread with a similar question on fuel systems except in the pump department: Fuel System Upgrade Questions
From what i understand they go 5/8" to the pump, 1/2" from the pump to the motor & 3/8" going back to the tank assuming you're using more than a stock pump.
2000 F-350 Lariat CCLB w. 335,000+ Mi
Tymar intake, Straight 4", 6.0 Intercooler, IDP Competition Fuel System, AC's, SB SD Clutch, ZF6 Short Shift Kit
Gearhead Tunes, Swamps IDM, Snow Performance Water/Meth, Isspro Performax Gauges & 08 Black Leather Seats
05 Harley's, Smoked tails, Weld Racing Sidewinder Wheels
Fried Piston, Re-building engine
330 RWHP Fuel Only - 363 RWHP w. Meth
Broke College kid... Eating Ramon to save for truck parts..
the1laf is offline
post #4 of 4 Old 05-06-2013, 08:32 AM Thread Starter
I have the driven diesel prepump kit and the hose is 3/8. I just wanted to know if it would matter if I just used -4an hose for my regulated return on the motor. I don't see a need where it would have to be -6an hose. Your only going to flow what the banjo bolts will let thru. -4an is about the same as 1/4. Idk. Just looking for advice
