Taking fox shocks off??? - Ford Powerstroke Diesel Forum
post #1 of 17 Old 05-01-2013, 06:50 AM Thread Starter
Hey guys, my shocks are discolored now and I would like to take them off and get them repainted. How in the world do I take them off and put them back on? Taking fox shocks off???-imageuploadedbyag-free1367419764.196172.jpgTaking fox shocks off???-imageuploadedbyag-free1367419780.488059.jpgTaking fox shocks off???-imageuploadedbyag-free1367419812.957005.jpg
Galileo is offline
post #2 of 17 Old 05-01-2013, 06:53 AM Thread Starter
Galileo is offline
post #3 of 17 Old 05-02-2013, 02:59 PM
blue99stroker's Avatar
Quoted: 270 Post(s)
just find where it mounts and unbolt it.
if they are just bolted to the shock hoop just unbolt them from the shock hoop. they dont do any weight bearing thats all up to the leaf springs.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is online now
post #4 of 17 Old 05-02-2013, 09:11 PM
700xxmaniac's Avatar
your gona wana lift your rear end up from the frame if thats a sping helper i see on the rear shocks
99 ford f-250 crew cab powerstroke
-skyjacker 6'' lift
- 395-70r-16 mickey tomson baja mtz
-sct tune
-stright pipe (vrrrooom)
-cops are in love with the thing
08 TRX700XX
-uni
-primary drive 13t
-pclll
-cp 11:1
01 recon es 250
-kenda 22'' bear claw
-53mph top speed
700xxmaniac is offline
post #5 of 17 Old 05-02-2013, 09:13 PM
Raul@Stealth Automotive's Avatar
i had the same shock hoop up front. your going to have to remove the whole shock hoop to get them out.....
Raul@Stealth Automotive is offline
post #6 of 17 Old 05-03-2013, 06:07 AM
Quoted: 28 Post(s)
The rear end is a link set up, no leaf springs from what i can see.
Just jack the rear end up, put jack stands under the frame in front of the rear tires and then just unbolt them. As long as you can get the rear end up high enough you should be able to extend the coilovers to their full length and get all the froce off them so they slide rigth out.
The front just unbolt, they will be pressurized so the shaft will extend all the way out once you pull them off so you will need some muscle putting them back in. To install i reccomend standing above the shock and putting your weight on it to compress it. once you have it at the right height to fit back in to be mounted tie a rope around both ends to keep it from expanding and then slip it in and bolt it up!
CarportMechanic is offline
post #7 of 17 Old 05-03-2013, 06:09 AM
Quoted: 28 Post(s)
I hope your wrong cause that shock hoop is welded to his frame......
There should just be some bolts going through the eye of the shock at both ends.
post #8 of 17 Old 05-04-2013, 12:18 PM
Quoted: 270 Post(s)
wow he does not have any leaf springs thats odd.
how do those things do while towing? i hope it does not compromise the purpose of the truck.
post #9 of 17 Old 05-04-2013, 12:28 PM Thread Starter
What are you guys talking about? There are leaf springs on here....
Galileo is offline
post #10 of 17 Old 05-04-2013, 12:35 PM
sprksonu's Avatar
There are leafs on the front but not the rear
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
