I'm worried, Edge Evolution II stuck on 89% - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-27-2013, 08:16 AM Thread Starter
mtmc's Avatar
Okay I have a 2002 F250 with the 7.3. Well I bought a edge evolution II programmer for it. Supposedly it was used but when I received it, everything was still in the factory plastic and looked an smelled new. It's not VIN locked or anything and the diagnostics and monitoring worked like a charm. Anyway, now I'm trying to load the level 1 tow program on it and everything was going great until it got to the Writing Section 4 of 4 and it's been stuck on 89% for about 20 minutes. I'm worried and dont want to turn the key off or unplug it with fear that it will screw up the PCM. What do I do? It's Saturday and edge isn't open to ask them. : (
2002 F250 CCSB True Blue L2
5" Turbo Back MBRP, 7" Tip Muffler Delete Spectre CAI Foil Delete Edge Evolution II Glowshift Gauges Hutch/Harpoon Mod Leveled 285/75 Cooper AT3 16x8 Dick Cepek DC2 Mile Marker 449SS Goodmark 2" Steel Cowl SS Step Bars
mtmc is offline
post #2 of 6 Old 04-27-2013, 01:52 PM
JSchuricht's Avatar
I would give it a hour. If it hasn't moved at that point you don't have much choice but to turn the key off. If your lucky you will be able to retry the burn. If your not so lucky, you will need to tow the truck to a dealer to have it re-flashed and pay to have the edge unlocked.
JSchuricht is offline
post #3 of 6 Old 04-27-2013, 02:04 PM Thread Starter
mtmc's Avatar
Ok so it sat on 89% for over an hour so I decided to pull the trigger and unplug it from the OBD port. I then turned the key off and tried to start it and noticed I didn't hear all of the normal priming at startup. So it was just cranking and cranking and never did start. So I went inside and tried to use the Fusion software that came with it. It kept getting hung up and telling me it couldn't access some .dll file. So after finally finding an updated version of the fusion software on edge's website, I was able to update the tuner. It prompted me to try it on the truck and when I did, thankfully it gave me a message that the previous tune was unsuccessful. I loaded the stock tune back on it and everything is so far so good. I assume the update was what was needed but I'm still a little gunshy and not sure if I should try the tune again or not.
mtmc is offline
post #4 of 6 Old 04-27-2013, 02:07 PM
rdaffin's Avatar
Go for it. Update should have solved the problem.
Sent from AutoGuide.com App
2004 CCSB 4x4, blue spring, SCT , 4" exhaust, Gearhead tunes, egr delete, ELC-1, Coolant filter, ARP Studs, CCV Mod, 6" lift, 35" Toyo A/T II.
rdaffin is offline
post #5 of 6 Old 04-28-2013, 01:52 PM
Ace7.3's Avatar
I've had this problem with mine a few times. Unplug the edge, turn key off, plug edge back in, follow prompts to go to main menu. Then retry changing power levels. And speaking of updates, I need to check mine
2002 3/4 Lariat,DIY,Zoodad,boost fooler,CCV,HPX,EBPV,Wicked wheel,Auto Meter gauges,Edge Evo II 100 horse,MBRP 4",203*
Ace7.3 is offline
post #6 of 6 Old 04-28-2013, 02:37 PM
Quoted: 48 Post(s)
letting something sit for that long is worse than just unplugging it and letting it go into recovery. glad you didn't smoke your pcm!
drunk on diesel is offline
Tags
7.3 , edge , evolution , stuck
