Temp gauge - Ford Powerstroke Diesel Forum
Old 02-18-2008, 02:38 PM
Temp gauge
My gauges will be here tomorrow. I need to buy the tap and drill bit on my way home from work. I will install the pyro probe in the drive side manifold. I need to know what size tap and drill bit I will need.
Old 02-18-2008, 02:44 PM
Send a message via ICQ to Lord Tauk Send a message via AIM to Lord Tauk
Letter Q Drill will work (.332")
1/8 NPT tap.
Old 02-18-2008, 02:46 PM
What he said... But the bit size I just find one that is smaller and run with it. Never let me down yet.
Old 02-18-2008, 02:56 PM
Do you guys have any tips. What type of drill bit should it be a harden bit location of the pyro probe in the manifold.
Old 02-18-2008, 02:59 PM
Drill with what ever bit you have. Hell I have used a unibit before (steped bit). Drill, tap, and install. Dont grease the bit, dont step from one size up, dont vac the hole, dont use a magnet... Drill, tap and install. DONE.
I have done 20+ pyros and never once had an issue.
Old 02-18-2008, 03:04 PM
International Threat
Agree'd ^
I haven't done 20 but I've done quite a few.
Drill a pilot hole.
Drill with the bit you need.
Tap it.
Install it.
Start it.
Old 02-18-2008, 03:08 PM
you dont think there is a need to get the rest of the metel shavings out?
Thanks for the help guys.
Old 02-18-2008, 03:15 PM
Originally Posted by jo4450 View Post
you don't think there is a need to get the rest of the metel shavings out?
There are several different ways to look at this...
1. You are drilling up, ask yourself, have you ever seen anything fall up? Nor have I
2. The turbo is designed to see temps of over 1200 on a regular basis, do you think some small cast iron (read soft) shavings are going to hurt it moving thru at idle speeds?
The point is, your drilling up, and if you drill once and only once then 99.9% of the shavings will fall in your eyes, down your shirt and into your nose (those hurt A LOT!). Anything that does defi gravity and fall up will blow right past the exhaust wheel at idle and out the tail pipe.
No disrespect meant if any is taken.
Do these go upstream or downstream of the turbo?
