K&N Filter ? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-25-2013, 11:21 PM Thread Starter
K&N Filter ?
I picked up a 01 that has had one run in it . I plan to remove and get a new filter as soon as I get it home. At tranny shop now. Was bad when I picked up the truck. I ran the big honking filter on my Cummins. I will probably go a simalar route on this F 250 . What if any thing do I need to do to the turbo with a K & N being run in it before I picked it up . Thanks Mike
MGEOD is offline
post #2 of 7 Old 04-26-2013, 01:51 AM
JSchuricht's Avatar
Pull the intake tube and take a look in the turbo. You will see some oil from the CCV, that's normal. What you don't want to see is the blades looking like they have been sandblasted.
JSchuricht is offline
post #3 of 7 Old 04-26-2013, 08:18 AM
BSkopnik's Avatar
Can keep the kn tubing. Ditch the filter get the AFE replacement. Lol my .02. Tired of having to reoil the damn filter.
Sent from AutoGuide.com App
02 F350 CC LB 4x4 Lariat
Done: K&N CIA, Torklift Camper tie down system, Firestone Ride Rite Air Suspension(Dual guage control, w/ reservoir tank), Autometer 3 Pillar guage(Boost,EGT,Tranny Temp), Vision Type 81 19.5" w/ Goodyear G622 RSD 245/70r19.5 LRG, 03-07 power/heat/light mirror conversion, Sinister Coolant Filter kit.
ToDo: Powerslot Cryo rotors, Hawke SD pads, 6.0L Tranny Cooler, Oil Temp/Pressure, Fuel Pressure and Diff Temp guages.
BSkopnik is offline
post #4 of 7 Old 04-26-2013, 04:53 PM Thread Starter
Thanks , will do as soon as I get it home .
MGEOD is offline
post #5 of 7 Old 04-29-2013, 07:08 AM
If you can post up the dimensions of the K&N I can get you the part number for a dry filter to make it a little easier on you if you are looking to swap filters.
aFePower_Shaun is offline
post #6 of 7 Old 04-29-2013, 08:20 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Go ahead and put this bich on most 7.3L guys run this filter
B085011 - 6637 - ECB DONALDSON REPLACEMENT FOR NAPA 6637 - Filter Products
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #7 of 7 Old 04-29-2013, 08:33 AM
PowerStrokeBren's Avatar
Amsoil has a replacement filter for the k&n part number is EAAU-4095 and its a dry filter also.
2000 F-350 7.3L Powerstroke
Autometer gauges
Banks 6 gun tuner
Banks Wastegate Actuator
ATS Turbo Housing with WW
K&N CAI
Magnaflow 4" turboback
2 1/2 Leveling kit
35" MT ATZ
PowerStrokeBren is offline
