ICP - Ford Powerstroke Diesel Forum
post #1 of 13 Old 02-17-2008, 01:09 PM Thread Starter
ONE BAD EXCURSION's Avatar
ICP
My icp has oil in the plug. Is this normal or is it leaking.
2002 EXCURSION 7.3 WITH BANKS 4" EXHAUST, SWAMPS STAGE 1 SPLIT SHOT INJECTORS S175/146, S&B COLD AIR INTAKE, FPR MOD WITH FUEL GAUGE, TUNES BY MATT @ GEARHEAD AUTOMOTIVE , AUTOMETER GAUGES PYRO, TRANS TEMP, BOOST, 6.0L INTERCOOLER, TN BB TURBO, DINO CROSS CONNECT KIT, DINO HIGH PRESSURE CROSSOVER, ADRENALINE HPOP FROM DIESELSITE
ONE BAD EXCURSION is offline
post #2 of 13 Old 02-17-2008, 01:31 PM
John Wood Nut Swinger
strokin_early_99's Avatar
Not normal. Clean it out and keep an eye on it for a few days. If it fills with oil again, replace it.
(Born on 11-20-98) F350 CC LWB 4X4
north of 480hp and south of 13.7sec
Bored with current setup
Family of 5 saved by Grace.....
Sponsored by Left Coast Diesel in Concord, Ca
Anything BUT Conservative Performance
strokin_early_99 is offline
post #3 of 13 Old 02-17-2008, 01:56 PM
7.3ford350's Avatar
Send a message via AIM to 7.3ford350
i no i should no this but what is the ICP ?
2000 F-350 Beans diesel performance stage 1 injectors, Beans tunes 6 pos, EBPV delete, ITP boost regualtor, itp pre pump/fuel tank kit,dino fuel cross connect kit and hpx line, trans,pyro,boost and fuel presure autometer ultralite gauges, full exhaust, wicked wheel, Intake, BD Waste Gate, foil delete
2008 F-550 6.4 12ft dump
2006 F-450 6.0 12' dump
2003 F-250 5.4 gas
2006 Ford Ranger
CAT 305CCR EXCAVATOR, 289C SKIDSTEER, 257B SKIDSTEER
7.3ford350 is offline
post #4 of 13 Old 02-17-2008, 01:58 PM
International Threat
Marty's Avatar
Injector Control Pressure
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #5 of 13 Old 02-17-2008, 02:01 PM
Marty's Avatar
Like strokin said, it needs to be cleaned out and checked. Did you do the 10k mod? If not, then more then likely the sensor is failing and will have to be replaced (they're not cheap). It should throw a code and an SES light when it starts to loose contact and will make your truck run slow.
2001 F250
11.62 @ 115.79
Elkton, Maryland
Marty is offline
post #6 of 13 Old 02-17-2008, 02:01 PM
7.3ford350's Avatar
its a sensor correct? and where is it?
2003 F-250 5.4 gas
2006 Ford Ranger
post #7 of 13 Old 02-17-2008, 02:05 PM
Marty's Avatar
ICP is not a sensor, but there is a sensor that monitors it.
It's where the 10k goes...
2001 F250
11.62 @ 115.79
Elkton, Maryland
Marty is offline
post #8 of 13 Old 02-17-2008, 02:12 PM
7.3ford350's Avatar
oh ok i gotcha..thanks
2003 F-250 5.4 gas
2006 Ford Ranger
post #9 of 13 Old 02-17-2008, 02:57 PM
sawyer1's Avatar
I just went through this they are not cheap 200.00 bucks my bet is you need a new one i guess there gold plated to help with resistance.
-Sawyer-
USAF COP!!
2000 F-250 Lariat, 142,000mi automatic trans.
SOLD SOLD
New rig 2006 dodge cummins mega cab
sawyer1 is offline
post #10 of 13 Old 02-17-2008, 04:26 PM Thread Starter
I have some problems. When I come to a stop sometimes it will cut off. It acts like it runs out of fuel. My fuel pressure at idle is around 75psi. I have not checked it going down the road. I pulled the plug out of the icp and it was full of oil.
