DP Tuner pics???? - Ford Powerstroke Diesel Forum
Old 02-16-2008, 03:07 PM
DP Tuner pics????
Any one got any pictures of their DP Tuner (either style) installed in truck. Trying to see what looks good and what doesn't work. I was thinking about putting one where the normal 4X4 Switch would go considering it's a two wheel drive truck. Anyone got any pics?
Old 02-16-2008, 03:23 PM
International Threat
I have a picture in my head. I put mine where the under dash comes together with those 4 tabs and then my knee kept hitting it and changing programs LOL. So I shifted it up on the right hand side of the steering wheel behind the ignition - I can always see what position it is in and now I don't hit it with my knee anymore.
Old 02-16-2008, 03:24 PM
PS - I got the one w/ green LED and it looks factory
Old 02-16-2008, 03:32 PM
Did you get the circular gauge one or the other box one?
Old 02-16-2008, 03:33 PM
box one...
Old 02-16-2008, 03:37 PM
box one...
Okay, thanks for the image. What would you think of the circular one mounted inside the dash (yes that means cutting) where the 4 wheel drive select switch is? (it'd go in a 2WD F250)
Old 02-16-2008, 03:39 PM
http://www.dp-tuner.com/Documentatio...stallation.pdf
Scroll down through the instructions and you will see how Jody installed the remote switcher in his truck pre custom mounting option.
EX Remote Switcher Mount
this shows it with the custom mount for it installed behind a gauge.
And here gauge switch installed in my Excursion with over the steering wheel mount.
Old 02-16-2008, 06:52 PM
I installed mine where the 4x4 knob would be in that little square. I have a six speed so my 4x4 is on the floor and that square was blank, so it worked out perfectly. Just drilled a hole out just big enough for the connection to fit through put some velcro on on the swith and wallah. Looks real nice.
Old 02-16-2008, 07:10 PM
Originally Posted by SeeYa View Post
That is badazz... once I get my truck straightened out a bit I'll start spending money on some more stuff like this.
Old 02-16-2008, 09:33 PM
SEEYA I like that it looks good I have the mine mounted to the right of my column see pic in garage, but I need to look into getting yours. Nice
