Ok i have nerver used any synthetic oils in anything. I was thinking bout changing my engine and tranny to synthetic. Switching from regular oil to synthetic is there any ways i should go about changing them? is there a certain procedure to follow when switching oils? Have no clue or should i just stay with what i use now. engine i run Delo 400 and tranny when i changed the filter i used coastal atf. Let me know what yall think!
You change the engine oil as normal.
The transmission you have to drain the torque convertor or flush the convertor. Look here for a good write-up: 4R100/E4OD Trans Flush Procedure - Powerstroke Nation FWIW, I have been running Amsoil heavy duty diesel and marine oil for the last 150,000 miles. Oil analasys has always come back lower than normal averages. I just today took off my dual remote/bypass and switched back to Delo 400. The Amsoil will hold up to a single HPOP truck for 18-20K miles without any problems. Over half those miles are towing. After I switched to my twin HPOP's my oil will only last 10-11K. I can get 5K out of dino oil so I did not find it a financial advantage to run Amsoil in my truck any longer. |
