water methanol hp gains?? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-22-2013, 08:31 PM Thread Starter
ole96stroker's Avatar
Is there any real hp gain's with snow's water meth system except cooler egt's? thanks
******1996 ford f250 powerstroke 5 spd 4x4******
***170,000 miles, ts 6 pos, intake, exhuast***
ole96stroker is offline
post #2 of 3 Old 04-23-2013, 09:05 AM
layson's Avatar
Quoted: 79 Post(s)
Oh yes, but I just used it for cooling.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #3 of 3 Old 04-23-2013, 02:45 PM
Premium Starfish Member
AzPatMan's Avatar
Quoted: 31 Post(s)
It's kind of a hand in hand situation.
Think of the Water/Meth kit as an after-cooler. You're getting air 'post intercooler', but you still have enough heat generated by the engines to cause the water/meth molecules to separate. And when that does - it absorbs some of the heat, effectively providing the cooler air charge. Cooler/denser air will always give you a gain on HP/TQ (to a point).
Kind of a neat science behind it all!
2003 EX, 7.3L 4inch Lift, Nitto Trail Grappler's, KMC XD Spy's
220k Miles, Currently 605tq, 312hp
AzPatMan is offline
