leveling kit - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-15-2008, 05:53 PM Thread Starter
onecrazyblackredenck's Avatar
leveling kit
can someone post up some pics of their truxk with leveling kit running 35's?????????? I want to get a leveling kit but not sure if I want a leveling kit or a 4" lift......
03 F250 4wd auto strait pipe quad cab lariat 33x12.50x18
84 K5 blazer CUCV M1008 dana 70 front and rear, detroit lockers front and rear, 45" tractor tires, 6.2 diesel
1978 cj5 built 304 lots and lots of rust
onecrazyblackredenck is offline
post #2 of 8 Old 02-15-2008, 05:56 PM
Raul@Stealth Automotive's Avatar
here is a pic with my 3.5" fabtech hanger kit.... one thing i have learned after 3 diff lifts on my truck... if your thinking between 2 diff lift sizes always go with the larger one... you will be kicking yourself in the rear if you go with just the leveling kit after you do it
Raul@Stealth Automotive is offline
post #3 of 8 Old 02-15-2008, 06:02 PM
sawyer1's Avatar
I agree with raul!
Pic In the sig not 35's but 33's i think it would be close with 35's but iv seen them they look good. They look like a tank. But id go with the 4inch lift
-Sawyer-
USAF COP!!
2000 F-250 Lariat, 142,000mi automatic trans.
SOLD SOLD
New rig 2006 dodge cummins mega cab
sawyer1 is offline
post #4 of 8 Old 02-15-2008, 06:23 PM
cchase's Avatar
yeah I went with the 4 inch, so now I am putting the leveling kit and some custom crap to make it 6. but thats my limite i dont want to blow out any driveshafts
On vacation from a truck for a year or...
Looking at 6.4s Moving in a few months then hopefully buying my dream truck!!!
Driving an Audi till then...
but at work I drive
16 E-450s 7.3 powerstroke Ambulances
7 Duramaxes
1 GMC Kodiak Ambulance
NO CUMMINS.....
cchase is offline
post #5 of 8 Old 02-15-2008, 06:33 PM Thread Starter
well I dont want to regear lol I will probablly go with a 4" lift and run 36's..........do you think that will do my tranny in? I dont do much towing but I have a heavy foot and like to see black smoke
post #6 of 8 Old 02-15-2008, 06:34 PM Thread Starter
What sizee tire are you running there.?
post #7 of 8 Old 02-15-2008, 07:11 PM
i was running 35's.... if you only want to go 4" run 35's if you go to 36's your speedo is gonna be off around 3-5mph which will also through off when your trans shifts in and out of gears and out of overdrive..... it will create more heat which in turn will wear out your trans faster
post #8 of 8 Old 02-15-2008, 07:25 PM
mountainlander's Avatar
A custom tune should be able to move the shift points to the correct rpm...
Robert Fenton
'Bessie' --2004 Excursion Limited 4x4 6.0L --SOLD with a blown head gasket, Bad EGR Valve and Cooler, Bad oil cooler
And then there was one:
4" Turbo Back from Gus @
--in garage waiting to be installed
Support our boys through
mountainlander is offline
