FPR shim - Ford Powerstroke Diesel Forum
post #1 of 42 Old 02-15-2008, 01:21 PM Thread Starter
7.3ford350's Avatar
Send a message via AIM to 7.3ford350
FPR shim
well i did the FPR shim today becouse my psi is about 56psi and would like closer to 65 psi. i used a BB and did eveything i was suspose to do,made sure the spring didnt get messed up or anything. got in the truck and my psi went up to 100 psi. so i took it apart and did 3 other time, tried differnt bb's and still hit 100psi. just wondering if i did something wroung. i took it out now becouse i no a 100 psi would likely scew something up. has anyone else had this problem. can i do anything else to achevie 65 psi?
thanks
2000 F-350 Beans diesel performance stage 1 injectors, Beans tunes 6 pos, EBPV delete, ITP boost regualtor, itp pre pump/fuel tank kit,dino fuel cross connect kit and hpx line, trans,pyro,boost and fuel presure autometer ultralite gauges, full exhaust, wicked wheel, Intake, BD Waste Gate, foil delete
2008 F-550 6.4 12ft dump
2006 F-450 6.0 12' dump
2003 F-250 5.4 gas
2006 Ford Ranger
CAT 305CCR EXCAVATOR, 289C SKIDSTEER, 257B SKIDSTEER
7.3ford350 is offline
post #2 of 42 Old 02-15-2008, 01:26 PM
Other vehicle is an F250
Hank's Avatar
Yeah.......I have read where you can use an allen head screw and grind the head down until you achive the desired pressure. I guess the threaded part of the bolt slips in the spring. Do a search I'm sure you will find something.
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #3 of 42 Old 02-15-2008, 01:35 PM Thread Starter
7.3ford350's Avatar
yeah i fourd the one two. i just dont have access to a grinder so that why i was trying the bb, but i dont no if that would either becouse i dont no if u could grind the head smaller then the size of a bb.
2003 F-250 5.4 gas
2006 Ford Ranger
post #4 of 42 Old 02-15-2008, 01:48 PM
What year you got? Are you sure the bb is resting somewhat inside the opening of the spring? I took my fpr completely off so I could get it right. That way you can just drop the bb in and place the spring on top if it, also get the point in the middle of the brass bolt centered into the spring. Also clean the screen while you have it out, don`t forget the o-ring on the screen and the brass bolt if you decide to go that route. The bb size to use is 0.177 or 4.5mm which are the same.
97 F-350, 7.3 psd, xlt, limited edition, obs, dually, E40d at, 410 r axle, reg. cab, 8ft bed, 145000 miles, DIY Tymar intake (napa filter) CCV mod. fpr bb mod, HPX crossover pipe, SS Bully steps, Reese Fifth wheel hitch, CB Radio, 3" DP /4" back w/cat delete and 4" flow-thru muffler w/5" tip.
Triflex is offline
post #5 of 42 Old 02-15-2008, 02:20 PM Thread Starter
7.3ford350's Avatar
i got a 2000, i took the cover off then pulled the spring and the brass thing out, place the bb down in the brass thing and put the spring back in and put the cover back on, and made sure the spring was in the center of it, then put the cover back on.. it seamed like it had alot of tension on it.
2003 F-250 5.4 gas
2006 Ford Ranger
post #6 of 42 Old 02-15-2008, 02:24 PM
PSDfan99's Avatar
Pull the spring out, leave the brass thing in. Put a tiny bit of grease on the end of the spring and then stick the BB on the end of the spring. The grease acts as a "glue" to hold the BB so it won't fall off the spring while installing it. Then insert the spring inside the FPR mechanism in the bowl with the BB headed outward. The BB wants to be touching the FPR cap (the one that has the 2 torx bolts holding it on the bowl). If you do that, it should be fine.
Early 99 F-350
4" lift on 33's
Tymar Intake, Isspro Gauges, Modded IDM, HPX, Boost Fooler, 4" Exhaust
-BTS Tranny
-76mm Sledgehammer
-Swamps Tuning
-230cc Casserly Hybrids
-T.E. Modded 17* HPOP
-ARP's, Chromoly's, 910's
-ITP RR
-Jake
PSDfan99 is offline
post #7 of 42 Old 02-15-2008, 02:27 PM
pojo4223's Avatar
Send a message via AIM to pojo4223
i put the bb between the spring and the aluminum cover, i dont know if it would make any difference but id try it that way, spring,bb,cover(cap) and be careful when tightening the fuel line back onto the cap, if you tighten it to much you may crack the threads!
-PJ
~Early 99' F350 PSD 4X4~
>Tymar 6637 intake
>Edge evolution
>CCV Mod
>FPR Shim
>HPX Oil Line- Performance Oil Products
>TC Lockup Switch
>BFG All Terrains 305/70/16
>IDM Mod
>Isspro Gauges- Pyro, Tranny, Boost
>FBD 4" Turbo Back, Straight Pipe Exhaust
>Ford Re-manufactured Tranmission
>Rebuilt Stock Garret Turbo. (Parts from Ron's Turbo Service)
What's Next
>BTS Valve body (hopefully sooner rather than later)
>Lit Tow Mirrors
pojo4223 is offline
post #8 of 42 Old 02-15-2008, 02:32 PM
OK the hole the bb goes in is actually two holes. A big opening where you start to screw in the brass bolt. down inside and at the bottom of that is a smaller hole and it has a lip so if you don`t take the fpr off you will have to take a small screwdriver etc. to push the bb into the small hole then the spring also goes inside the small hole and sits there thats why you then have to line up the center of the bolt within the center of the spring to keep everything straight. If you are not having issues w/your truck, idle,throttle etc. I would forget it.
Triflex is offline
post #9 of 42 Old 02-15-2008, 02:34 PM
I like the grease way PSDfan99 does it. much eisier.
Triflex is offline
post #10 of 42 Old 02-15-2008, 02:34 PM
PSDfan99's Avatar
The FPR design is different on the OBS trucks like yours compared to the Superduties, if that is what your referring to.
Early 99 F-350
4" lift on 33's
-BTS Tranny
-76mm Sledgehammer
-Swamps Tuning
-ITP RR
-Jake
PSDfan99 is offline
