ok tranny guys this is whats goin in.
This is a list of parts that my tranny guy says would be goin into my rebuild. What do you think?
Sprag kit Power valve Boost valve Low/Rev mod 45 element sprag 6 pinion front and rear planets ( if i need them ) Shift kit Lockup valve Carbon fiber band Band servo 4th gear kryptonite clutches 2nd gear Z-pack Direct clutch power pack Case bushings Gasket set OD spiral ring Hardend input shaft Pump Correction Package Billet Converter Low rev clutches |
Sounds like a pretty therow list of parts to me but I'd would look in to getting a deep trans pan holds another couple quarts of oil and has cooling fins
You need 6 gear planets, no matter what anyone says, just ask BTS, John Wood, ATS, Suncoast, ect..... Make sure if you have 6 gear planets already they are steel. Do not use aluminum, they will fail. I broke a 6 gear aluminum planet in my first trans with 300hp.
Not trying to be a a$$ but I have learned the hard way about a lot of this stuff. I just don't want you to get down the road a year and have it go on you. My first trans broke the foreword planet and it took the trans case with it. $3200 for the trans and another $1200 for a trans case. Last edited by strokin_early_99; 02-15-2008 at 09:21 AM. |
ok so i need planet gears. Ya thats what i keep tellin this guy. i said if im gana build it make it so i never have to build it again and he said ok. I forgot to put the deep pan too so it will have that. All the stuff listed would run me $2,232
Strokin early 99 do you think im goin down the wrong path with this stuff?
its probably not gonna end up being much cheaper than getting one of johns tranny's dude
Only problem I see is the hard parts are being used over which probably killed it in the first place. I was told by a very knowledgeable person in the know(see sig) that the internals turn like a jump rope instead of a straight line. I wish you all the luck with your rebuild.
its says that his tranny that would hold appro. 600 hp was 4900 is that right
And just what does Brian so special to straighten out the "jump rope"? |
