Preping for 238/100's - Ford Powerstroke Diesel Forum
post #1 of 28 Old 04-21-2013, 11:29 PM Thread Starter
JSchuricht's Avatar
Working on a deal to get 238/100 Rosewood sticks for my 00. It might not be necessary but I am also planning on installing springs, rods and studs at the same time. Here's what I am planning on using...
ARP studs from Strictly Diesel
Comp Cams 910-16 Valve Spring Set
Smith Brothers Push Rods from Riffraff
Is there anything I should change from this list, also are .015 shims what I need or should I get the .030 shims?
JSchuricht is offline
post #2 of 28 Old 04-22-2013, 05:10 PM
01Crewcab7.3's Avatar
Sounds perfect. Not sure on the shims though, hopefully someone else will.
Sent from AutoGuide.com App
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
post #3 of 28 Old 04-22-2013, 05:34 PM
OL' OutLaw's Avatar
if you're gonna hit it that hard, I'd for sure put a Mellings LOPOP and a Fluidampr on it JS.....
'97 Centurion. F350 4x4 CCLB
Full Force 180cc Stage I's, D66, SRP-1.1, ARP, Banks IC, DIY E-Fuel, EBPV Del & Gut'd Ped., BD Exhaust Brake., SD IDM, HPX, BstFoolr, 4" DP - 4" exh,
6.0 Fan, 180 T-Stat, DIY Don.105006 AF, CCV Mod, BTS, W/ SD Trans Lines, Tru-Cool Max, PML Trans Pan, Bumper Mod, IssPro Gauges, Fluidampr, Mellings LPOP.....
Tuned by "The WildMan".
OL' OutLaw is offline
post #4 of 28 Old 04-22-2013, 09:22 PM Thread Starter
JSchuricht's Avatar
I am assuming it's the Melling M208 that your talking about. Price isn't bad, most of what I have found is people replacing their stock one at 200k due to it being worn out. I am at 199k so it's probably not a bad idea but do you think a stock pump couldn't feed a SRP-1 sufficiently?
I'm not finding much on the Fluidampr other than a price, what's it's benefit.
Sticking a link to a writeup here so I can find it later.
post #5 of 28 Old 04-23-2013, 06:04 AM
OL' OutLaw's Avatar
I think a new stock pump would be ok, I do think the Mellings is a bit better...they designed it to run just a bit more pressure, but at higher Volume, which would help keep an SRP 1.1 filled better.
get it here :
http://www.strictlydiesel.com/p-2689...-oil-pump.aspx
the Fluidampr is an improved Vibration Damper, and you can read about them here JS :
The Original Fluidampr
I worked the logging Industry for many years, and all Cummins, Detroit Diesel, and Caterpillar engines manufactured in the last 35-40 years have ALL come with Fluidamprs. the reason they use them is because they work.
the highest Recommendation I can give any part is to put it on MY truck.
there is one on my truck, and I would NOT be without it.
post #6 of 28 Old 04-24-2013, 11:07 AM
joeyd61's Avatar
238/100 with correct turbo and HPOP should be appx 500 hp..I did 510 with mine.. don't forget a trans (if you are stock R4100)
joeyd61 is offline
post #7 of 28 Old 04-24-2013, 01:21 PM Thread Starter
JSchuricht's Avatar
Yep, the trans is my suspected weakest point. I had it rebuilt 10k ago with supposedly upgraded parts but the TC came apart recently. I cleaned everything up, didn't find any damage, and installed a BTS VB, PI TC and billet input. Still have no faith in it due to the inexperienced guy I had put it back together.
The turbo will be the second weakest link. I have a 38r with a WW that I still need to install. It will be at it's limit with these sticks. I have a SRP-1 for oil so I should be good there.
post #8 of 28 Old 04-24-2013, 01:44 PM
c69ss396's Avatar
I'd throw in some ARP rod bolts while your in there.
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #9 of 28 Old 04-24-2013, 05:08 PM Thread Starter
JSchuricht's Avatar
I'm not even sure how to respond to that one Frank. I should check that I have forged rods but with a build date of 12/99 it shouldn't be a issue. I think I will save the bottom end work for my next rig, don't really feel like pulling the block out on this one.
post #10 of 28 Old 04-24-2013, 05:18 PM
c69ss396's Avatar
If your pulling the heads another hour or so you and can have the the bottom end out. It's all down hill from there, 8 bell housing bolts 4 flex plate bolts and 2 motor mounts and its out. I'd freshen up the bottom end if it was me, but then again you know I've never had a issue spending someone else's money.
c69ss396 is offline
