What's all required for zf6 swap? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-17-2013, 11:32 AM Thread Starter
I have a lead on a 01 with the zf6. Just curious on what is all needed to make the swap into my 2000
Matt
2000 F250 ccsb 86k
Pro Comp 6" lift
Stock engine... For now!!!
Hefel86 is offline
post #2 of 3 Old 04-17-2013, 06:49 PM
JSchuricht's Avatar
Everything.
Trans hump, pcm, harness, transfer case or input shaft, drive shafts, steering column cover, blankoff for cluster, pedals, master/slave/line. On the second hand, you what you really want to do is just ship the whole thing to me.
JSchuricht is offline
post #3 of 3 Old 04-19-2013, 05:59 PM
Im_Strokin_ur_Cummins's Avatar
Location: Lowville, New York. Studying Mechanical Eng. @ Suny Canton
There is a thread in the general discusion that talks about what is needed and what has to be done it should be right at the top. It will walk you through everything you need to know
FUELED BY HATERS
Jack'em up high.Fat chicks cant jump!
E99 7.3 F-250XLT
304,345 miles and still running strong
ext cab
DIY 6637 Intake
5in straight pipe to Aussie stacks
PHP 6pos
Boost,tran,and EGT Gauges
4in lift
Some body rust and oil leaks
CB radio
Pretty Girl sittin next to me
Im_Strokin_ur_Cummins is offline
