modified hpop or twins?
Whats your oppinion on a modified hpop vs. twins? (otherthan price)
well look at it this way. if you go with twins and one goes out, u can still drive the truck on the single. If you lose the single modded hpop...your truck is down until its fixed
hpop dont fail very often and a single like the ones dieselsite has will make plenty of oil for your setup for less money than a dual
Come on Todd, we're talking about end of the world Armageddon circumstances here! If the Cummins God of Doom rained hell on powerstroke owners and destroyed ONE hpop on each powerstroke our friend here would have ONE left....and the master plan would be foiled...
....i'm off to bed now |
wow my head hurts now from thinking that one thru !!!! haha
new to some of the terms. what is the hpop? thanks
high preassure oil pump if fires your injectors
I have stealth twins and will say there is a huge difference between the stealths and even a very good factory pump. My factory pump put out 2900psi and my twins pump out 3500psi with custom DP tunes for it. The difference is night and day. I also have the 4 line setup
is that related to the plug i did the 10k resistor mod to? thanks
kind of....the sensor you did the 10K mod to is the sensor that measures the pressure that the pump is putting out...
