EDM injectors? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-09-2008, 09:38 AM Thread Starter
Send a message via AIM to hartman99
Question EDM injectors?
Can some please explain to me what these are? I run EDM machine for a living and was wondering if i could just get a old set of stock injectors and cut them bigger of somthign. Ive seen ads for thses type of injectors and would like some info on the. Thanks!
hartman99 is offline
post #2 of 11 Old 02-10-2008, 09:31 PM
lilredpowerstroke's Avatar
EDM is like the abrasive putty, right?? Just run your injector tips through it and let us know how it turns out.
T.J.
2003 F-350 dually 6.0
Centennial Edition
Straight exhaust 34x10.50 Swampers on Black Rock Stars
Been a member longer than most of the moderators
Thats why I said most Tiff
Think you can trust the government? Ask an American Indian!
My old truck in action
lilredpowerstroke is offline
post #3 of 11 Old 02-11-2008, 10:58 AM
lukecline
Guest
Posts: n/a
Quoted: Post(s)
no your thinking of EH or Extrude Hone. EDM is electro discharge machine, it uses electricity to enlarge the holes.
post #4 of 11 Old 02-12-2008, 05:46 PM Thread Starter
Yea i can EDM drill holes down to .010 diameter, and wire EDM Verl small holes too. anyone ever heard of anyone ever doing this to there injectors? How big are the holes in a stock injector anyways? any help?
post #5 of 11 Old 02-12-2008, 05:53 PM
.0055" Biggins are .0075"
Diesel Monkey is offline
post #6 of 11 Old 02-12-2008, 06:16 PM
lukecline
Guest
Posts: n/a
Quoted: Post(s)
I think your confused diesel monkey. stock is somewhere around .0065, i run .012. Hartman unless you can precisely control the angle of the hole then i wouldnt try it. If you get a hole just a bit off your spray pattern would be way out of wack.
post #7 of 11 Old 02-12-2008, 06:30 PM
CSIPSD's Avatar
My tips I am running now are three .010 holes and four stock...
My new ones are .008
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #8 of 11 Old 02-13-2008, 07:23 PM Thread Starter
Hmmmm... yea i can do angles tapers, lands ect but 10 thou is startin to push it and i dont think i could go any smaller than that. How many hole are typicaly in the injector anywas?
post #9 of 11 Old 02-13-2008, 07:26 PM
International Threat
Marty's Avatar
Mine are 0.008 as well... 0.010 are big, and 0.012 are huge.
Like luke said though, they need to be at a precise angle for proper fuel atomization.
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #10 of 11 Old 02-13-2008, 07:36 PM
John Wood Nut Swinger
strokin_early_99's Avatar
stock nozzles are .0058-.0062 according to DDP. Then you open them up from there. I run .0065 just because I want to keep the smoke and EGT's down while towing.
Luke, With .0012, no wonder you keep breaking engine parts and pieces. Dang that is a lot of fuel.
(Born on 11-20-98) F350 CC LWB 4X4
north of 480hp and south of 13.7sec
Bored with current setup
Family of 5 saved by Grace.....
Sponsored by Left Coast Diesel in Concord, Ca
Anything BUT Conservative Performance
strokin_early_99 is offline
