6637 - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-11-2013, 05:55 AM Thread Starter
early99psd's Avatar
Quoted: 12 Post(s)
I have a E99 and I went to install a 6637 filter kit from riffraff, and the 45 degree piece of tube does not work with the intake tube. It needs to be straight. Is it possible to have the later air box in my truck? or did the dealer do any kind of a recall or something and change it?
MB HPOP, PHP Hydra, AFE stage 2, 4" turbo back exhaust, gutted cat, ford reman trans, JW valve body, 6.0 trans cooler, EGT trans temp boost gauges, Hutch and Harpoon mod, riffraf FRx, Pro Comp leveling kit, 1" zone shackels, 08 rear diff cover, 315 Toyo AT2,
early99psd is offline
post #2 of 6 Old 04-11-2013, 06:44 AM
dannanw's Avatar
Quoted: 54 Post(s)
Garage
it might have a late tube on it, I'd see if they'll exhange ot get a piece of 4in w/out the bend at a exh shop or someplace...I have E99 and riff raff kit here's a pict for you if it helps...
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #3 of 6 Old 04-11-2013, 06:46 AM Thread Starter
early99psd's Avatar
Quoted: 12 Post(s)
I think it has the late tube for sure on it. It is longer than yours.
Sent from AutoGuide.com App
post #4 of 6 Old 04-11-2013, 06:53 AM
dannanw's Avatar
Quoted: 54 Post(s)
Garage
I was going to switch out the tube but it wasn't worth it for me cost wise... If I'd had a late tube I was going to go with the ais system for durability. Hope you get it figured out, Clay at Riff-Raff is a good guy for as much as I've delt with.
dannanw is offline
post #5 of 6 Old 04-11-2013, 07:35 AM
timmyboy76's Avatar
if you got a late tube, then all you need is the 4in exhaust coupling, for it to work. Its how mines' set-up.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #6 of 6 Old 04-11-2013, 09:50 AM Thread Starter
early99psd's Avatar
Quoted: 12 Post(s)
That's what I ended up doing. Just thought it is weird that its the late tube.
