what camshaft to use - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-11-2013, 12:37 AM Thread Starter
I'm rebuilding my 99 7.3. Ford overhaul kit ,rebuilt heads, head studs, T500 HPOP, garret ball bearing turbo, ebv delete, stage 1 or 2 injecters (didn't decide yet),PHP chip. When I took it apart I found the can was bad should I put a stock camshaft in (fords list cost is $630) or put a gear head performance stage 1 camshaft in for $525 plus new pushrods and valve springs. I use the truck mostly for towing 10000 to 12000 lb. Any other modifications that I should do while the truck is apart? Thanks for any input
Late 1999 f350 4x4 drw crew cab auto trans, DI 4 position chip, AFE II air filter,ftvb, 4"down pipe into 2 5" stacks, ww, ccv mode, autometer gauges , 135,000 miles. Late 1999 f250 ext cab.4x4 auto FF stage 1 injectors non EBPV pedestal, GTP 38R turbo, hydra with powerstruck tunes, gauges. 213000 miles.
Jdg5147 is offline
post #2 of 3 Old 04-11-2013, 08:13 AM
OL' OutLaw's Avatar
I'd use the stock cam, put Stage I's in it, a new Mellings LPOP, and a Fluidampr
'97 Centurion. F350 4x4 CCLB
Full Force 180cc Stage I's, D66, SRP-1.1, ARP, Banks IC, DIY E-Fuel, EBPV Del & Gut'd Ped., BD Exhaust Brake., SD IDM, HPX, BstFoolr, 4" DP - 4" exh,
6.0 Fan, 180 T-Stat, DIY Don.105006 AF, CCV Mod, BTS, W/ SD Trans Lines, Tru-Cool Max, PML Trans Pan, Bumper Mod, IssPro Gauges, Fluidampr, Mellings LPOP.....
Tuned by "The WildMan".
OL' OutLaw is offline
post #3 of 3 Old 04-12-2013, 12:20 AM
dentexpowerstroke's Avatar
I want a cam from Matt in my truck, but if my truck was stock I would run that. Seems to be more of an upside to a cam when you are pushing more power.
Sold 2001 f250 ccsb 4x4 400/400, dual terminators, swamps 80mm bfh, headers, bts and all the usual supporting mods. 715hp fuel only.
06 f250 ccsb king ranch
12 f250 lariat ultimate
dentexpowerstroke is offline
