Best 7.3 programmer - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-09-2013, 07:01 AM Thread Starter
Quoted: 3 Post(s)
Best 7.3 programmer
Looking for a good programmer but want one I can mount on the dash and make changes on the fly, One with the screen display. I looked at Bully Dog but dont see many reviews about it..
Buckscent is offline
post #2 of 12 Old 04-09-2013, 11:06 AM
Justin@DP-Tuner's Avatar
Quoted: 63 Post(s)
With a programmer on a 7.3L, you cannot really change tunes on the fly. The reason being that they flash the PCM and the truck must be off to do that. Any product that claims it is shift on the fly is not really a programmer. It is just an ICP fooler. However, a chip that plugs into the PCM is switch on the fly. Most people opt to go with a chip when they want to be able to change tunes on the fly.
You can also get a monitor and a chip and have the best of both worlds. We have a product called the Infinity which is a monitor and a programmer. It will monitor generic and Ford enhanced data, run diagnostic tests, tune, datalog, and more. You can also add additional inputs to it so it can monitor data that the PCM does not see. This would include EGT and fuel pressure. Although the Infinity itself cannot change tunes on the fly, you will be able to connect it to a multi-position chip and have it work as a switching unit for the chip. The product that will enable this should be available very shortly.
HERE is a link to the Infinity if you would like to check it out.
Let me know if you have any questions.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #3 of 12 Old 04-10-2013, 09:46 AM
Sawed Off's Avatar
I stuck a SCT tuner on my buddys 7.3 Works pretty good... but still not a shift on the fly.
2010 SUPERDUTY
6.4 CREWCAB
Mods so far!!
Smoked Recon lights
Predator8 wheels
Toyo open country tires
Dpf/Doc delete
H&S tuned
S&B cold air intake
Sawed Off is offline
post #4 of 12 Old 04-26-2013, 08:48 PM
MA-n-GA's Avatar
Send a message via Yahoo to MA-n-GA
I recently bought an 02 and it has a Bully Dog GT(gauge tuner) on it. Only had truck a few days and still learning the tuner. Can adjust throttle senetivity, can swap the display to monitor all kinds of systems(4 on screen at once), and claims to be change on fly. On left side of tuner can swap between stock tune, tow, performance, and extreme. I havent tried messing with it yet to I learn little more about the tuner.
Mike
2002--4x4--F-250 Turbo'd 7.3 Crew Cab--
93 Summer Edition mustang-- Coyote swap underway --""FOR SALE""
MA-n-GA is offline
post #5 of 12 Old 04-26-2013, 10:20 PM
dentexpowerstroke's Avatar
The best one is a ts with custom tunes. If you want a display look at an edge cs or cts monitor. I would really waste my money on anything other than custom tunes.
Sold 2001 f250 ccsb 4x4 400/400, dual terminators, swamps 80mm bfh, headers, bts and all the usual supporting mods. 715hp fuel only.
06 f250 ccsb king ranch
12 f250 lariat ultimate
dentexpowerstroke is offline
post #6 of 12 Old 04-30-2013, 10:10 PM
Gunner
GunnerB's Avatar
I run the PHP Hydra.
2003 F250 7.3L CC XLT SB
AIS Intake
4.5" ICON Lift
Pre-Pump/Coolant/Transmission Filter
PHP Hydra
6.0L Cooler
ISSPRO EGT/BOOST/TRANS
B&W Turnoverball
Firestone Airbags
Warn Premium Hubs
Cobra 29 LX BT
2002 EX LIMITED 7.3L
DS Trans Cooler
Bilsteins
GunnerB is offline
post #7 of 12 Old 05-01-2013, 06:24 AM
Quoted: 861 Post(s)
Feedback Score: 3 reviews
X2 what Justin said. 6pos tied into the Infinity would absolutely be the way to go. You also get built in, that's similar to AutoEnginuity, diagnostic software.
Add it up price difference.
Good quality gauges, pillar pod, AE (having to mess around with a laptop and battery going dead, plus the time to install all the gauges.
VS
Just plug in the Infinity and a little bit of setup time.
I really wish they had this two years ago. I would have bought it in a heartbeat. I dont have it yet, but its on my list. So nice to be able to have engine diagnostics all the time instead of waiting until you get back home or having to go to the dealer if your on vacation.
Corey@CNCFAB is offline
post #8 of 12 Old 05-01-2013, 10:29 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
TS chip with custom tunes...then get quality pillar gauges Isspro's..will end up cheaper.
CT Performance, Inc. is offline
post #9 of 12 Old 05-01-2013, 12:03 PM
Quoted: 63 Post(s)
VS
That is correct.
Purchasing a chip, gauges, and AE separately will run you more than just purchasing the Infinity.
Actually, for the price of a chip, some good gauges, and the AE Ford Enhanced bundle, you could pay about the same amount for our Infinity-PL which comes with 12 pre-loaded tunes for automatics and 10 pre-loaded tunes for manuals.
DP-Tuner
Like us on
Justin Bochmann
post #10 of 12 Old 12-04-2013, 07:57 PM
Ancientwayz's Avatar
Justin,
Your last post said, "about the same amount for our Infinity-PL which comes with 12 pre-loaded tunes for automatics", I like the sound of that deal, but does that allow for "on the fly" tuning changes as the previouly mentioned 6 position chip?
Ancientwayz is offline
