6" exaust tip. Guages? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-05-2008, 10:17 AM Thread Starter
I`m doing a 3" dp w/4" straight pipe w/cat/muff delete. Several posters say go with a 5" tip, some say 6". Whats the difference? maybe a more mellow sound? lower sound. Also, since I don`t plan any other mods, (It`s a road driver), Are my stock injectors OK with this setup? Do I need exaust guages? Sorry about all the questions, I`m kinda new. Thank goodness I found this site as it has really helped.
97 F-350, 7.3 psd, xlt, limited edition, obs, dually, E40d at, 410 r axle, reg. cab, 8ft bed, 145000 miles, DIY Tymar intake (napa filter) CCV mod. fpr bb mod, HPX crossover pipe, SS Bully steps, Reese Fifth wheel hitch, CB Radio, 3" DP /4" back w/cat delete and 4" flow-thru muffler w/5" tip.
Triflex is offline
post #2 of 5 Old 02-05-2008, 10:27 AM
slammedSI's Avatar
The tip is going to be strictly looks. Its allways good to have a set of guages. weather its stock or not. EGT,BOOST, and Trans Temp are the 3 you would want. Doing a Turbo back Exhaust will not harm any one the other parts on your motor.
-Bobby Crews- AKA Dr. Cookie Cutter!
2012 Ford F150 Ecoboost
-STOCK-
A 7.3 with an edge should never get into a race. Unless it's with a kid on a bicycle.. and the bike has a flat.
slammedSI is offline
post #3 of 5 Old 02-05-2008, 10:32 AM
smokeyd's Avatar
go 7 inch
smokeyd is offline
post #4 of 5 Old 02-05-2008, 10:36 AM
CSIPSD's Avatar
Gauges should have come from the factory... Tip wise, like the other poster said, just for looks... If your at stock height stick with a 5" if your lifted then 6" looks good.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #5 of 5 Old 02-05-2008, 10:41 AM Thread Starter
Thanks to all. That is exactly the info I was looking for. Thanks again. Great site.
Triflex is offline
