installed a TS chip now wont start. - Ford Powerstroke Diesel Forum
post #1 of 30 Old 04-07-2013, 10:47 AM Thread Starter
it was running great last night after we installed it. we got everything on made sure the settings were working then left it in stock almost all night. went and parked it and this morning it wont start. spent about 20-30 minutes just workin the key. would get it to fire every now and then but itld just die right away. and its only mid 40s out so it shouldnt be hard to start at all. any ideas?
2002 F250
Leveled on 35s
[SIGPIC][/SIGPIC]
Cduff is offline
post #2 of 30 Old 04-07-2013, 11:03 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Take the chip out and try again.
With the KOEO, does the WTS light come on and the fuel pump run?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 30 Old 04-07-2013, 11:06 AM
Wannabitawerm's Avatar
I agree. Pull the chip and try to start. Should be fine. If it fails to start without the chip, it may just a coincidental unrelated issue.
Sent from AutoGuide.com App
Wannabitawerm is offline
post #4 of 30 Old 04-07-2013, 11:08 AM Thread Starter
all the lights and everything come on and the WTS does its normal cycle doesnt stay on our anything. ill try pulling the chip today.
2002 F250
Leveled on 35s
[SIGPIC][/SIGPIC]
Cduff is offline
post #5 of 30 Old 04-07-2013, 01:31 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
clean the contacts on the pcm better.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #6 of 30 Old 04-07-2013, 01:42 PM Thread Starter
i think my problem is i may have cleaned them too much. i read somewhere, i think off another forum, if you wear the tin off it wont work. i just barely got through the tin if i remember right when i was scraping the connection. ill see what i can do though.
2002 F250
Leveled on 35s
[SIGPIC][/SIGPIC]
Cduff is offline
post #7 of 30 Old 04-07-2013, 02:44 PM Thread Starter
so i took it out and it fired right up. drove around for a while and got the engine warm and plugged it back in and it started just fine. kind of weird but it makes sense its easier to start a warm engine
2002 F250
Leveled on 35s
[SIGPIC][/SIGPIC]
Cduff is offline
post #8 of 30 Old 04-07-2013, 04:20 PM
Macon's Avatar
Seems like you just had a bad connection the first time you installed it. IF you don't do it right, you can have issues. Be sure to tape the chip in place (cover the hole with tape) to keep it from backing out and messing you up again.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #9 of 30 Old 04-07-2013, 07:43 PM
Quoted: 258 Post(s)
duck tape is your friend!
post #10 of 30 Old 04-07-2013, 08:38 PM Thread Starter
thanks guys! i tucked it in there real good today and started up just fine on a cold engine and again after i shut it off a few minutes later. i guess the real test is tomorrow but tape is definitely goin on and some good zip ties for the cable.
2002 F250
Leveled on 35s
[SIGPIC][/SIGPIC]
Cduff is offline
