stage 2 injectors reg fuel return kit hpx line question
I'm looking at dynomite diesel performances 120 hp injectors, is it a good idea to install itp regulated fuel return kit and a itp hpx oil line (connects oil pressure rails) to help these injectors or will these injectors function perfect without? also where should i hook a colbalt fuel pressure guage sending unit?
Uhhhhh.....since he posted it in the 7.3 forum, I would venture to say it is not a 6.ooooooh.....
A fass is not needed to keep up with stage 2's. I ran my B codes off of a stock pump. Neither of the ITP items are mandatory however to get the most out of the injectors they are necessary. I put new lines on my fuel bowl and fed the heads from the rear. Then I put a cross over line on the fronts of the heads to help equalize fuel pressure. The reason for the HPX line is to keep the oil pressure up. The firing order is 1-2-7-3-4-5-6-8. The oil pressure recovery time for the 7-3 and 6-8 cycle are the reason. This also why the reason for the fuel system upgrades, to keep pressure to those injectors. On the back of the fuel bowl(towards the fire wall) is a plug that has uses an allan wrench to get it out. That is a #4 ORB fitting port, you will keed an adaptor to put in your fuel pressure gauge but that is where it goes. Last edited by strokin_early_99; 02-02-2008 at 09:53 AM. |
2001 f250 lariat 7.3
hey that sounds great but i want to install a fuel guage inside my cab also the reg kit comes with the adjustable under the hood. i assume i should be watching how low the pressure goes when i hammer on it to pass.
I'm new to the site and heve not figured out how to put all my mods up. i only have a few
Oops... missed that one, sorry.
6.ooooooh...
what do you mean by "The gauge comes with the adjustable under the hood"? You want to see how far the pressure drops under WOT(wide open throttle). Idle pressure, cruising pressue and WOT pressure. |
what would the normal be for all three pressures?
