Question for you Evolution 2 guys. - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-01-2008, 04:32 PM Thread Starter
I just installed the EVO 2. Love it! However, on the site it says L1 is 60HP, L2 is 80HP and L3 is 100HP. The manual says L1 is 0HP (trans), L2 is 60HP, and L3 is 100HP. My module tells me L1 is tow, L2 is race and L3 is extreme. I have read here in previous posts from last year (i use the search button quite often) that you have to upgrade to get the 60, 80, 100. Well I never did that. So what tunes exactly do I have? My rig is a 2002 F350 dually 7.3L with the 6 speed manual tranny. Did it recognize that and offer up the 60, 80, 100? Or do all latest modules ship this way? Or do I still have the trans, 60, 100 tunes? I am just curious. I just put it on L3. I haven't tried anything else.
Thanks in advance! Oh yeah, one more thing.... I love this site! You guys have a ton of info here.
Debo is offline
post #2 of 11 Old 02-01-2008, 09:59 PM
Where did you read you have to upgrade to get the 60hp tune? I never upgraded and when mine is on the first level its very obvious that there is added horsepower and torque over stock.
01 Ford F250 supercab 4x4 7.3L
mods: Edge evolution 2, tymar intake, 4inch exhaust, zoo-dad, 4inch lift, 295x75x16 BFG AT
MMA21 is offline
post #3 of 11 Old 02-01-2008, 10:20 PM Thread Starter
just read that the first level is trans only in the manual. ill see if i can find the link where i saw it here also later and post it. i was just curious at the time i installed it. i have since changed it and noticed the difference.
thank you. i feel a bit better now. wasn't exactly sure at first.
Debo is offline
post #4 of 11 Old 02-02-2008, 10:37 AM
I know in the gas rigs the first level is a trans only level and it doesnt add any performance.
MMA21 is offline
post #5 of 11 Old 02-02-2008, 04:47 PM Thread Starter
Just my luck.... I haven't even had it 24 hours and I am already having problems with it. I noticed this morning that the module is turning off while I am driving. Truck still runs fine but the module just shuts off. I have to disconnect the OBD cable and reconnect then it starts working again. Can't call Edge Tech Support until Monday. Tried updating it but it wont connect to the the device. That could be my laptop though. Its not the greatest. Anyone ever done the diagnostic self test on the evo before? just curious what the communication test is supposed to report back if anything. all i get is a blank screen.
Debo is offline
post #6 of 11 Old 02-04-2008, 06:14 PM Thread Starter
Well I just wanted to post that Edge called me first thing this morning and helped me troubleshoot my problem. They are sending me a cable to replace the one I have. They think that is the problem. If that doesn't fix it they will send out an entire new module to replace it. That is awesome customer service. Granted we all expect "this kind" of service with a new product but we seldom receive it with anything these days. So I am happy.
I just wanted to update the forum in case others happen to search for the same issue.
Debo is offline
post #7 of 11 Old 02-05-2008, 04:49 AM
I just got a Evo 2 and love it. I had the same question about the HP and level settings. Per Edge the manual is old and the correct HP are 60, 80, 100. Currently I am using the L2 80hp setting and have no problems
DavidJanney is offline
post #8 of 11 Old 02-05-2008, 04:53 AM
ADMIN AND TECH
SCUFFY828's Avatar
i had bought the edge evo 2 and had good luck with it , im actually was gonna set it to stock tune and just use it as gauges, and i bought a custom tune set up from tony wildman , mine also started just shutting off just whenever it wanted to, let me know what it takes to get it fixed
ITS STOCK
SCUFFY828 is offline
post #9 of 11 Old 02-05-2008, 08:40 AM
onecrazyblackredenck's Avatar
okay so is the evo 2 better than a ts with tony tunes? Can you get tony tunes on an evo 2?
NOT TRYING TO HI JACK JUST CURIOUS SORRY
03 F250 4wd auto strait pipe quad cab lariat 33x12.50x18
84 K5 blazer CUCV M1008 dana 70 front and rear, detroit lockers front and rear, 45" tractor tires, 6.2 diesel
1978 cj5 built 304 lots and lots of rust
onecrazyblackredenck is offline
post #10 of 11 Old 02-05-2008, 09:33 AM
tubular031's Avatar
DP tuner was the only one that i know of who could program the evo2. I called jody and asked if he still programs them and he said edge pulled the plug on his programming and he no longer does it. I got my evo 2 in the mail yesterday and will install it this weekend.
I figured that when i am ready for more, I will keep the evo as gauges and a code reader then talk to tony for a custom chip. for you guys wanting to do this now or later like me, make sure that you return the evo to stock or bad things will probably happen!
tonys tunes are going to be better then the evo for sure. i got the evo because i dont like the many gauge look, i want a code reader and i got it for a SWEET deal i could not say no to!
Just a basic 01 F350 CCLB SRW -Good from a far but far from good
tubular031 is offline
