just installed dp-tuner have question.... - Ford Powerstroke Diesel Forum
Old 01-31-2008, 03:05 PM
i just got done installing my chip, runs and drives great, what a difference. my only question/concern is that my overdrive light is flashing on my shifter. is this normal? i didnt read anything in the directions about that or anything. thanks
eden
Old 01-31-2008, 03:07 PM
KVFD
never heard of the light flashing like that! u need to get your gauges though
Old 01-31-2008, 03:12 PM
Hey man i have the Dp and its not supose to, but i cant rember what causes it. Make sure you get your gauges very soon though. You will need them.
Old 01-31-2008, 03:14 PM
you have a driveline problem. Get a code pulled and you will find out what exactly is causing it. Definatel will pull up a drivetrain code.
Old 01-31-2008, 03:15 PM
pretty sure that is for a tranny code if i remember right
Old 01-31-2008, 03:17 PM
ya but it flashed before i started driving the truck. and only kicks on when i switch from stock tune to any other setting
Old 01-31-2008, 03:18 PM
International Threat
Get the codes pulled... could be as simple as one of the 2 or 3 sensors from the tranny to the rear diff.
allot of ythe time the od light flashing if from a speed sensor malfunction. but i would have the codes pulled. it can be from any electronic problem with the vehicle. my moms f150 started flashing when her alternator was getting weak.
A shop will be able to tell you exactly what it is.
Old 01-31-2008, 03:19 PM
yes ive also heard that it could be a rear diff. speed sensor
