TS Chip and Factory High Idle? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-01-2013, 04:29 PM Thread Starter
Will a chip alter or disable the stock high idle and EBPV system?
I'm planning on buying a custom ts 6 position chip (PHP Phoenix most likely) and I havent been able to find a conclusive answer through searches. I really dont have a use for a high idle setting on the chip as long as the factory high idle will still be working...
2015 F350 CCSB XLT 4X4 Mostly stock, for now.
ccmac is offline
post #2 of 7 Old 04-01-2013, 04:45 PM
Eric's Avatar
Feedback Score: 6 reviews
The high idle and ebpv work normally on all 5 tunes on my DP tuner
Early 99 F250 with a bunch of extra junk...
Eric is offline
post #3 of 7 Old 04-02-2013, 06:38 AM
SeeYa's Avatar
There's a reason to have a dedicated Hi-Idle tune. Factory High idle does not help warm up the truck faster at all. It will, but it takes much longer because it's on a timer and when you hit the brake it goes away. The idea of a HI-Idle tune is for getting the truck warmed up faster in winter, having a colder air conditioning out-put in summer and to use equipment from the trucks. We have many customers with welders and compressors and the HI-Idle helps power their equipment. Having an Excursion with dual air I use mine in the summer time to put out colder air. If you've ever been to Georgia in the summer months you know what I'm talking about.
To answer you question, No a chip will not alter your factory fast idle.
Diane
Custom Tuning-Computer Chips
Flash Programmers-Aftermarket parts
Ford Power Stroke Engine and Transmission Tuning Specialist since 2004.
828-221-0076
SeeYa is offline
post #4 of 7 Old 04-02-2013, 07:25 AM
481-SCO's Avatar
I have the TS Chip and like DP-Tuner said it does not alter the factory high idel.My 7.3 will idel at apx .7 RPM's stock (in high idel) but will Idel at 1.0 RPM's with the Chip it makes it very nice at time's. I'm very happy with my TS Chip
Name is Allen
97 F350 Crew Cab 7.3 5 speed 6 position TS chip,Glow Shift gauges Boost,fuel pressure, and EGT has a flat bed.
Keep Oklahoma Powerstrokes alive
481-SCO is offline
post #5 of 7 Old 04-02-2013, 01:52 PM
LoganFogg's Avatar
it dosent alter it forever but when u click it to the 2nd position is goes into high idle then when you click it off it come out of high idle i personally dont use it its unnecessary abuse on the motor it idles at a certain place for a reason
LoganFogg is offline
post #6 of 7 Old 04-02-2013, 04:01 PM
RexF350's Avatar
I have the tyrant 6 position, warm up idle is not affected with it either. I use my high idle setting in 4 wheel drive low to creep along. I've done this to feed cows when I was by myself. Do not try this at home!
RexF350 is offline
post #7 of 7 Old 04-02-2013, 07:07 PM
Joel's Avatar
Quoted: 10 Post(s)
Haha, thats awesome!
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
