fuel pressure gauge - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-31-2013, 05:17 AM Thread Starter
Redlazer's Avatar
fuel pressure gauge
I'm looking at getting gauges for my truck. I'm looking at going with EGT, Boost, and maybe fuel pressure n the HPOP. Is the fuel pressure worth getting is my question? Is a air intake temp gauge worth getting? Or is the HPOP gauge? Also is there any other gauges that I should look at?
early 99 Red F-250 XL SD, 7.3L, 6-speed manual, Extended Cab, Long Bed, 4x4 Off Road, and Reflexxion Cowl Hood, Ion Alloy 183 wheels, 05 headlights with 6000k AC HID kit, and led turn signals, Ford ASI filter w/ zoodad mod and foam sleeve, TS 6 position chip, Auto Meter Z series Boost and EGT gauges, and straight pipe oem exhaust. .
CAROLINA GRAY BOY
Redlazer is offline
post #2 of 11 Old 03-31-2013, 05:46 AM
jesilvas's Avatar
Quoted: 3 Post(s)
After doing EGT, boost, trans, and ECT, I would want to go back with a digital gauge setup.
With digital gauges, you can monitor anything that the PCM does. Such as ECT, EOT, trans temp, IAT, boost, EBP, BARO, ICP, IPR, and many others. You'd have to add EGT and fuel pressure aftermarket, but that's not a big deal.
But for you with a manual, EGT, boost, fuel pressure, and ICP, would be the top four.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 11 Old 03-31-2013, 06:09 AM Thread Starter
Redlazer's Avatar
ICP gauge?
CAROLINA GRAY BOY
Redlazer is offline
post #4 of 11 Old 03-31-2013, 07:29 AM
Seth14's Avatar
I bought an edge insight cts monitor, after fighting standard gauges. The cts is a sweet little deal, and a lot less stress installing
Late 99, Blackwater long block, forged rods, ARP studs, 910 comp valve springs, stelite valves, 38R turbo, 238/100 hybrids, TS 6 position chip custom tuned by Beans, T500 hpop, FRx, Airdog 150, S&B intake, side piped, edge insight cts monitor, DC2 rims, Crusher tires, BTS transmission, 6.0 31 row tranny cooler, and lots of blue lights!!!!
Seth14 is offline
post #5 of 11 Old 03-31-2013, 07:54 AM
Joel's Avatar
Quoted: 10 Post(s)
The HPOP gauge isn't of much use to you without IPR duty cycle. The two readings go hand in hand and one is useless without the other.
EGT, Boost, Fuel pressure mechanical gauges and a Edge CS for the rest is my vote.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #6 of 11 Old 03-31-2013, 07:56 AM
jesilvas's Avatar
Quoted: 3 Post(s)
ICP is injector control pressure. high pressure oil.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 11 Old 03-31-2013, 07:58 AM Thread Starter
Redlazer's Avatar
does the edge insight allow you to monitor everything? I know it monitors EGT, and boost. If it can monitor everything why buy other gauges?
CAROLINA GRAY BOY
Redlazer is offline
post #8 of 11 Old 03-31-2013, 08:35 AM
Joel's Avatar
Quoted: 10 Post(s)
The edge can monitor everything itself, but you need to buy add on harnesses and they end up costing a lot.
That, and the edge can only read boost as high as the factory map will allow. Thats why i suggest going the route i listed. Cheapest way to monitor everything, plus real gauges are cool.
But if you prefer the clean look of a monitor only, just pay for the additional harnesses and sensors. But then I would get the CTS for its bigger screen over the CS.
In my truck I have 5 mechanical gauges and a CS mounted in y dash displaying 6 more PIDs. Gives me something to look at on my long, boring commutes
Joel is offline
post #9 of 11 Old 03-31-2013, 08:48 AM Thread Starter
Redlazer's Avatar
how high is the factory map on boost? on the edge websight it say it monitors fuel rail pressure. What is better to monitor fuel rail pressure or fuel pressure?
CAROLINA GRAY BOY
Redlazer is offline
post #10 of 11 Old 03-31-2013, 08:58 AM
jesilvas's Avatar
Quoted: 3 Post(s)
You don't have a high pressure fuel rail, so it won't monitor that. And there is no factory fuel pressure sensor, so it won't. That's an add on.
And the MAP sensor will read as high as your boost goes UNLESS you have a boost fooler.
4R100, 2wd
330,000 + miles
jesilvas is offline
