Fuel pump
I have a 2000 f250 7.3 diesel and i heard that it is better to get more fuel pressure with a different fuel pump, do they go through more fuel or not. Also on a stock fuel pump how do you turn it up to get more fuel.
you have a high pressure oil pump that drives your injectors...
you get a chip for more fuel. |
You can also do the FPR Shim for more fuel pressure
you can shim your fuel pressure regulator, there is a write up for it in the forums, which will boost your fuel pressure a little bit.
as far as "turning things up manually," thats it. |
ah you beat me to it... haha
I uploades some pics of the superduty fuel bowl and the BB going into the FPR.
FPR Mod pictures from friends & fun photos on webshots This is where the BB goes in the fuel pressure regulator(FPR) |
how do you turn up your fuel pump
you cant turn up the fuel pump. Just the pressure going into the injectors.
you don't turn it up, you shim the FPR.
is it a lot of work to shim it up and how do you do it
